Thanks for your report.
The gerber-to-SVG tool at
https://pogojig.jaseg.net/static/pogospace/index.html works fine for me. Is your browser maybe blocking Javascript? You can check the browser console for error messages from the gerber renderer itself.
The issue with your SVG upload seems to be that the renderer was unable to find board outline and pogo pin objects. If you can't get it to work feel free to email me the gerbers or SVG and I can try to reproduce your issue. DM me for my email.
As for storing files, the gerbers and SVG are not even uploaded to the server since the rendering is done 100% client-side in JavaScript. They are stored in your browser's site data though, so you can still see your past uploads the next time you open the site. If you upload an SVG file that is stored until an error occurs or processing is finished. The generated downloads (renders and 3D files) are stored for up to I think 48 hours, and are then automatically deleted. They are tied to your session, so nobody else can see them.
The system is keeping error logs for debugging, but those don't contain any identifiable information. Here's the processing log from yesterday's uploads:
-- Logs begin at Sat 2019-06-01 01:02:26 UTC. --
Nov 09 23:50:55 wendelstein.jaseg.net python3[125951]: INFO:root:Processing render job 15 session 4038a26b-2c1b-49ce-8624-40c520b354b9 from ###.###.###.### submitted 2019-11-09 23:50:54
Nov 09 23:50:55 wendelstein.jaseg.net sudo[247631]: root : TTY=unknown ; PWD=/var/lib/pogojig ; USER=root ; COMMAND=/usr/local/sbin/pogojig_generate.sh 4038a26b-2c1b-49ce-8624-40c520b354b9
Nov 09 23:50:55 wendelstein.jaseg.net sudo[247631]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 09 23:50:55 wendelstein.jaseg.net python3[125951]: Spawning container pogojig-b967afd906c03c86 on /var/lib/machines/pogojig/.#machine.1c7b569fd9e51a23.
Nov 09 23:50:55 wendelstein.jaseg.net python3[125951]: Press ^] three times within 1s to kill container.
Nov 09 23:50:56 wendelstein.jaseg.net python3[125951]: Sat Nov 9 23:50:56 UTC 2019
Nov 09 23:50:56 wendelstein.jaseg.net python3[125951]: Cleaning up previous output
Nov 09 23:50:56 wendelstein.jaseg.net python3[125951]: Rendering
Nov 09 23:50:56 wendelstein.jaseg.net python3[125951]: make: Entering directory '/mnt/sources'
Nov 09 23:50:56 wendelstein.jaseg.net python3[125951]: support/inkscape_svg_filter_layers.py input.svg src/input.preprocessed.svg --only --name "Test Points" "Mounting Holes" "Grip Slots" "Outline"
Nov 09 23:50:56 wendelstein.jaseg.net python3[125951]: support/inkscape_exporter.py src/input.preprocessed.svg src/input.preprocessed.dxf
Nov 09 23:51:01 wendelstein.jaseg.net python3[125951]: (inkscape:11): Gtk-WARNING **: 23:51:01.901: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file ?/root/.local/share/recently-used.xbel.J914A0?: No such file or directory
Nov 09 23:51:01 wendelstein.jaseg.net python3[125951]: (inkscape:11): Gtk-WARNING **: 23:51:01.902: Attempting to set the permissions of `/root/.local/share/recently-used.xbel', but failed: No such file or directory
Nov 09 23:51:02 wendelstein.jaseg.net python3[125951]: mkdir -p out
Nov 09 23:51:02 wendelstein.jaseg.net python3[125951]: openscad -o out/jig.stl src/jig.scad
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: group(){multmatrix([[1,0,0,0],[0,1,0,0], (0 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: union(){group(){multmatrix([[1,0,0,0],[0 (0 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: multmatrix([[1,0,0,0],[0,1,0,0],[0,0,1,1 (0 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: difference(){linear_extrude(height=15,ce (0 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: difference(){difference(){linear_extrude (0 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: union(){linear_extrude(height=9.2,center (53272 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: multmatrix([[1,0,0,0],[0,1,0,0],[0,0,1,- (53272 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: union(){multmatrix([[1,0,0,0],[0,1,0,0], (0 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: difference(){difference(){difference(){l (0 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: CGAL Cache hit: difference(){difference(){difference(){l (0 bytes)
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: Current top level object is empty.
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: make: *** [Makefile:21: out/jig.stl] Error 1
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: make: Leaving directory '/mnt/sources'
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: Container pogojig-b967afd906c03c86 failed with error code 2.
Nov 09 23:51:03 wendelstein.jaseg.net python3[125951]: INFO:root:Finishied processing render job 15
Nov 09 23:51:16 wendelstein.jaseg.net python3[125951]: INFO:root:Processing render job 16 session 4038a26b-2c1b-49ce-8624-40c520b354b9 from ###.###.###.### submitted 2019-11-09 23:51:16
Nov 09 23:51:16 wendelstein.jaseg.net sudo[247657]: root : TTY=unknown ; PWD=/var/lib/pogojig ; USER=root ; COMMAND=/usr/local/sbin/pogojig_generate.sh 4038a26b-2c1b-49ce-8624-40c520b354b9
Nov 09 23:51:16 wendelstein.jaseg.net sudo[247657]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 09 23:51:16 wendelstein.jaseg.net python3[125951]: Spawning container pogojig-a0b04b967942a28b on /var/lib/machines/pogojig/.#machine.749dbbb866706ff3.
Nov 09 23:51:16 wendelstein.jaseg.net python3[125951]: Press ^] three times within 1s to kill container.
Nov 09 23:51:17 wendelstein.jaseg.net python3[125951]: Sat Nov 9 23:51:17 UTC 2019
Nov 09 23:51:17 wendelstein.jaseg.net python3[125951]: Cleaning up previous output
Nov 09 23:51:17 wendelstein.jaseg.net python3[125951]: Rendering
Nov 09 23:51:17 wendelstein.jaseg.net python3[125951]: make: Entering directory '/mnt/sources'
Nov 09 23:51:17 wendelstein.jaseg.net python3[125951]: support/inkscape_svg_filter_layers.py input.svg src/input.preprocessed.svg --only --name "Test Points" "Mounting Holes" "Grip Slots" "Outline"
Nov 09 23:51:17 wendelstein.jaseg.net python3[125951]: support/inkscape_exporter.py src/input.preprocessed.svg src/input.preprocessed.dxf
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: Traceback (most recent call last):
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: File "support/inkscape_exporter.py", line 52, in <module>
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: effect.ExportEffect.check_document_units(args.infile)
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: File "/mnt/sources/support/pogojig/inkscape/effect.py", line 273, in check_document_units
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: 'Height of SVG document is not an absolute measure. See '
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: ValueError: Height of SVG document is not an absolute measure. See https://github.com/Feuermurmel/openscad-template/wiki/Absolute-Measurements
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: make: *** [Makefile:13: src/input.preprocessed.dxf] Error 1
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: make: Leaving directory '/mnt/sources'
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: Container pogojig-a0b04b967942a28b failed with error code 2.
Nov 09 23:51:18 wendelstein.jaseg.net python3[125951]: INFO:root:Finishied processing render job 16
Nov 09 23:54:06 wendelstein.jaseg.net python3[125951]: INFO:root:Processing render job 17 session 0e9a5b1d-3645-49eb-aa5a-1ddb31d703c3 from ###.###.###.### submitted 2019-11-09 23:54:06
Nov 09 23:54:06 wendelstein.jaseg.net sudo[247680]: root : TTY=unknown ; PWD=/var/lib/pogojig ; USER=root ; COMMAND=/usr/local/sbin/pogojig_generate.sh 0e9a5b1d-3645-49eb-aa5a-1ddb31d703c3
Nov 09 23:54:06 wendelstein.jaseg.net sudo[247680]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 09 23:54:06 wendelstein.jaseg.net python3[125951]: Spawning container pogojig-b3c9160f97499afe on /var/lib/machines/pogojig/.#machine.d2e67dd1f756c03f.
Nov 09 23:54:06 wendelstein.jaseg.net python3[125951]: Press ^] three times within 1s to kill container.
Nov 09 23:54:07 wendelstein.jaseg.net python3[125951]: Sat Nov 9 23:54:07 UTC 2019
Nov 09 23:54:07 wendelstein.jaseg.net python3[125951]: Cleaning up previous output
Nov 09 23:54:07 wendelstein.jaseg.net python3[125951]: Rendering
Nov 09 23:54:07 wendelstein.jaseg.net python3[125951]: make: Entering directory '/mnt/sources'
Nov 09 23:54:07 wendelstein.jaseg.net python3[125951]: support/inkscape_svg_filter_layers.py input.svg src/input.preprocessed.svg --only --name "Test Points" "Mounting Holes" "Grip Slots" "Outline"
Nov 09 23:54:07 wendelstein.jaseg.net python3[125951]: support/inkscape_exporter.py src/input.preprocessed.svg src/input.preprocessed.dxf
Nov 09 23:54:11 wendelstein.jaseg.net python3[125951]: (inkscape:11): Gtk-WARNING **: 23:54:11.637: Attempting to store changes into `/root/.local/share/recently-used.xbel', but failed: Failed to create file ?/root/.local/share/recently-used.xbel.P45AB0?: No such file or directory
Nov 09 23:54:11 wendelstein.jaseg.net python3[125951]: (inkscape:11): Gtk-WARNING **: 23:54:11.639: Attempting to set the permissions of `/root/.local/share/recently-used.xbel', but failed: No such file or directory
Nov 09 23:54:12 wendelstein.jaseg.net python3[125951]: mkdir -p out
Nov 09 23:54:12 wendelstein.jaseg.net python3[125951]: openscad -o out/jig.stl src/jig.scad
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: group(){multmatrix([[1,0,0,0],[0,1,0,0], (0 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: union(){group(){multmatrix([[1,0,0,0],[0 (0 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: multmatrix([[1,0,0,0],[0,1,0,0],[0,0,1,1 (0 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: difference(){linear_extrude(height=15,ce (0 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: difference(){difference(){linear_extrude (0 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: union(){linear_extrude(height=9.2,center (53272 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: multmatrix([[1,0,0,0],[0,1,0,0],[0,0,1,- (53272 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: union(){multmatrix([[1,0,0,0],[0,1,0,0], (0 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache insert: difference(){difference(){difference(){l (0 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: CGAL Cache hit: difference(){difference(){difference(){l (0 bytes)
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: Current top level object is empty.
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: make: *** [Makefile:21: out/jig.stl] Error 1
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: make: Leaving directory '/mnt/sources'
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: Container pogojig-b3c9160f97499afe failed with error code 2.
Nov 09 23:54:13 wendelstein.jaseg.net python3[125951]: INFO:root:Finishied processing render job 17
