Author Topic: I need help deciphering this card edge connector's datasheet.  (Read 1920 times)
Offline MarkSTopic starter
I'm trying to create a library in KiCAD for AMP card edge connector 5650090-9. datasheet I need to create the schematic and footprint for both the card edge and the connector.
This is a 160 position connector. The issue is with the card edge diagram on page two. Looking at the drawing, I see that there are Y spaces, a notch, and then X spaces. Going back to page one, I see that Y is 37 and X is 41. 41 + 37 x 2 = 156. To make it even more confusing, the "NO OF DUAL POSN" column right next to the X column on page one says 80. 41 + 37 = 78! Where are the four missing connections? While I do not need all of the 160 connections for my project (future expansion), I would like to get this right before I waste money on a board. It looks like the notch would hide four connections easily, but then why sell this as a 160-position connector?
I must be reading this wrong!
Offline forrestc
Re: I need help deciphering this card edge connector's datasheet.
« Reply #1 on: July 25, 2017, 04:20:16 am »
This appears to be a fencepost error.  Look it up if you don't know this term....
The sheet says 'X spaces', not 'X holes'.
If you want to be sure about this, get a connector and count.... but that's my best guess
« Last Edit: July 25, 2017, 04:22:03 am by forrestc »
The following users thanked this post: MarkS
Offline rs20
« Reply #2 on: July 25, 2017, 04:22:48 am »
You have five fingers, but only four gaps between your five fingers.
(41 + 1) + (37 + 1) = 80
« Reply #3 on: July 25, 2017, 04:23:30 am »
I mistook spaces for positions of the contacts. That makes sense.
Offline WastelandTek
« Reply #4 on: July 25, 2017, 04:42:26 am »
And I learned a term..."fencepost error"   excellent
« Last Edit: July 26, 2017, 01:59:32 pm by WastelandTek »
I'm new here, but I tend to be pretty gregarious, so if I'm out of my lane please call me out.
« Reply #5 on: July 26, 2017, 07:47:21 am »
Also known in the programming world as the "Off-by-one error."
