Author Topic: IEEE symbols  (Read 1588 times)
Offline JtroTechABTopic starter
  • Country: in
IEEE symbols
« on: January 12, 2019, 07:22:00 am »
Hello,
Is there any source from where I can get IEEE standard symbols for various components?
Online nctnico
Re: IEEE symbols
« Reply #1 on: January 12, 2019, 02:27:16 pm »
These should be part of the CAD package you are using. However for logic chips beyond single gates the IEEE symbols have been a massive failure. Nobody is using these.
Offline DerekG
Re: IEEE symbols
« Reply #2 on: January 13, 2019, 02:21:21 am »
Yes, this is pretty much correct. Just work off the datasheet recommendation by the component manufacturer & the footprint should work just fine. With SMD electro caps & inductors (for example) you might wish to extend the footprint to just outside the component extends to ensure the part can be easily replaced with a rework iron if required.
I also sat between Elvis & Bigfoot on the UFO.
