Author Topic: Integration in LTspice (Voltage across inductor)  (Read 820 times)
Offline FaringdonTopic starter
« on: June 26, 2022, 05:49:03 pm »
I am trying to see if the following “sdt” function in LTspice will integrate the voltage across the secondary of the current sense transformer? AYK, It should  integrate out to zero volts, but its rising away negative.
Have i done the integration right?
'Perfection' is the enemy of 'perfectly satisfactory'
