Author Topic: IPC Standards in pdf format  (Read 5215 times)
Offline EEVadityaTopic starter
« on: September 12, 2014, 09:48:26 am »
 Hello,
 I am searching for some IPC Standards in pdf format regarding PCB  Designing rules.
The IPC Standards which I am looking for are:
IPC-7525A
IPC-2222A
IPC-D-279
IPC-7351B
IPC-2221A
IPC-CM-770E
IPC-7530
I did search , but I am getting only the Table of Contents & not the entire document.Where I will get the Free Download?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: IPC Standards in pdf format
« Reply #1 on: September 12, 2014, 10:24:46 am »
Nowhere*.  IPC asks for purchase of its documents.
*Though it's been my experience that there's usually one or a few obscure servers with the PDFs available.  You're welcome to search around and see.
If you need that many standards in their entirety, you're probably working for, or doing work for, a real company.  Have them buy them.  If they don't want to, go work for someone else, you don't need that kind of ethical disregard over your head.
Seven Transistor Labs, LLC
