Author Topic: is it standard in use rectangle pad in + , - polar?  (Read 2595 times)
Offline nquantumTopic starter
  • Country: th
« on: November 03, 2015, 04:08:23 am »
Since I use Diptrace and I found polar-capacitor ex. electrolyte use rectangle PAD for their + polar. But LED use rectangle PAD for their - polar. So I have a doubt...  What is standard polar in use rectangle PAD? + or - ?
Say for ex.
When u use terminal , u put rectangle PAD on + or - ?
When use battery holder u use rectangle PAD for + or - ?
For 1st pin of DIP IC it easy to understand that to use rectangle but how about the polar? use + for rectangle or - for rectangle which one is better for good habit?
Before I always use rectangle for - polar , but once I see Diptrace capacitors library I have curiosity.
Offline fivefish
Re: is it standard in use rectangle pad in + , - polar?
« Reply #1 on: November 03, 2015, 10:25:14 am »
I don't care about the pads, they're all round in my projects.
But I'm very mindful of correct silkscreens.
For LEDs, I even put text where the "long leg" of the LED should go. (As some of my customers find that easier and simpler to understand.)
BTW: some LEDs have reverse orientation, short leg is Anode.
http://media.digikey.com/pdf/Data%20Sheets/Lite-On%20PDFs/LTL-4266N.pdf
« Last Edit: November 03, 2015, 10:31:04 am by fivefish »
Offline Psi
« Reply #2 on: November 03, 2015, 10:34:06 am »
SMT leds from "Bivar Inc"...
One yellow, one green.
Green one has a little green dot for anode
Yellow one has a little green dot for cathode
 :palm:
Online tszaboo
« Reply #3 on: November 03, 2015, 04:05:41 pm »
Rectangle pad is pin 1, whatever that is in your schematic.
  • Country: th
« Reply #4 on: November 04, 2015, 03:30:23 am »
Me : i mostly do in hobby so seldom use silkscreen coz it cost me double. But this cost me more time to check before operate , test , mod.
So i this use rectangle pad will cost me zero.
Make sense to use rectangle on pin1 however it still no clue where is + or - coz some time pin 1 is + sometime -
Offline Warhawk
    • Personal resume
« Reply #5 on: November 07, 2015, 10:07:16 am »
Be careful with that. I have a bag of white LEDs with "leg" polarity contrariwise than usual.
