One again, bezier curves - totally not needed on a PCB.
Photorealistic screen print - totally not needed by anyone ever on a PCB.
Rivets - installed tediously one by one rather than electroplate the whole lot at once.
I never said anything about "need" (as I've pointed out multiple times already), and tedium is irrelevant. As such, this is a
non sequitur from you; consider it dismissed as such.
You're the one claiming to be able to produce better PCB's at home than a factory. Factory's produce billions of PCB's per year reliably incredibly cheaply. Have you ever produced a single PCB ? If so, go on, lets all see your better than a factory can do PCB ? (despite claiming above you never even intend ever producing even a single one at home).
This red herring from you = your tacit agreement that "10K+ volumes" has nothing to do with making PCBs at home.
Attached is a photo of a simple PCB I knocked up for a home project. On it there are 182 plated through holes and only one through hole component. By far, the majority of holes are used stitch ground planes together to improve the EMC performance of the PCB itself since the board has an on board 2.4GHz radio. Cost of using rivets using your figures: ~$5.46, not including labour time to fit them, per PCB. I got 10 boards made in China, shipped half way round the world to the UK for about $20. I've populated 3 so far, all work perfectly.
$5.46 added to the cost is not expensive, much less "mega expensive". If I were to make a PCB at home, I'd only be making one example of any given design.
The NXP RF module in the middle (which is only about the size of the end of my thumb), has well over 100 plated through holes, just in the bit of board you can see that isn't covered by the screening can, all in an area less than the size of my thumb nail. Again, no through hole components, so strength isn't an issue, but they didn't just put them all there for a bit of a laugh.
They all serve a purpose to form a good RF conduit from the IC under the can to the antenna on the end (that track with loads of vias either side is I believe what is known as coplanar waveguide), and to stop bits of the ground plane acting as antenna's and radiating any unwanted harmonics.
I can buy those modules from Farnell in the UK for £6.63 each (~$8.19) in one offs. If using your method, the cost of the rivets alone would be $3, plus then there is the cost of the rest of the bare PCB (looks to be 4 layers) including loads of time (time = money) to fit the many many individual rivets, the IC, passives, crystal and the screening can that they all sit under, plus placing them, soldering them, testing the finished module, packaging them in tape & reel format, and shipping them half way round the world to the UK (according to the page on the Farnell website, they're made in the far east). I doubt very much that your "better" method would allow them to be so cheap whilst still allowing both NXP and Farnell to be able to make a profit on them.
How would your proposed "better than a factory can make" method cope with this ? You wouldn't even be able to produce a single board at home that could perform as well as the one that the module uses.
I never said "better than a factory
can make", and this isn't the first time I've pointed out that I never said that. Second, I've said more than once "within certain limitations". It doesn't matter how many examples you give of specific PCB designs that aren't particularly suited to making at home, because there are literally an unlimited number of designs which
are suited to making at home, both designs which have already been conceived and designs which are yet to be conceived.
Says the muppet
Comical Irony Alert, and Monkey See, Monkey Do.
who defines a better PCB to be one containing utterly pointless bezier curves and photorealistic silk screens.
Given that you conveniently "forgot" to include stronger through-holes / vias, this is a straw man from you. And yes, less limitations for a given design is better than more limitations.
Have you ever designed
Yes, one, but the other PCBs I've drawn up weren't my design, they were reproductions of old PCBs, and I've run into an annoying limitation of PCB design software, i.e., no way to natively draw a bezier curve to replicate the curvy traces that were common with old hand-drawn PCBs.
and produced even a single PCB ?
No, and I have no intentions of doing so. This is yet another thing I've already said multiple times, and at this point it is safe to say that you don't read so well.
You're the one that started the thread by making dumbest claim of the year!
You just tacitly (and unwittingly) claimed that you and every other naysayer who has posted on this thread is an idiot, given that none of you have been able to refute the alleged "dumbest claim of the year".
I've yet to see any one of the many industry professionals, or even hobbyists that have posted in this thread agree with you.
Facts aren't up for a vote. In fact, they aren't even debatable, but don't let that stop you from trying. The fact that nearly everything you have posted is a
non sequitur, with a good portion of those
non sequiturs being attributable to a reading comprehension failure, makes you particularly easy to argue with.
