Author Topic: LT-SPICE: Can't find definiton of  (Read 1337 times)
Offline wobbertTopic starter
« on: December 08, 2017, 04:28:58 pm »
Hi guys,
I'm walking into troubles with LT-SPICE. I try to define a parameter, but it seems not to work. I get the pop-up message 'Can't find definition of "RES1"', while I believe it has been defined properly. Does anybody knows the solution to this problem? I am using the latest version of LT-SPICE ("Oct 24 2017"), which I run in WINE under Ubuntu 16.04. The circuit is attached and the SPICE code is as follows:
Version 4
SHEET 1 880 680
WIRE 128 192 0 192
FLAG 0 272 0
FLAG 128 272 0
SYMBOL voltage 0 176 R0
WINDOW 3 36 68 Left 2
SYMATTR InstName V1
SYMATTR Value 2
SYMBOL res 112 176 R0
SYMATTR InstName R1
SYMATTR Value Res1
TEXT 32 120 Left 2 !.param Res1=1
TEXT -32 296 Left 2 !.tran 10u
Offline Kalvin
  • Embedded SW/HW.
Re: LT-SPICE: Can't find definiton of
« Reply #1 on: December 08, 2017, 04:46:10 pm »
The following users thanked this post: wobbert
« Reply #2 on: December 09, 2017, 10:45:03 am »
I'm a f*cking retard. Thanks you very much :) I tried a lot of possible solution, but clearly missed the obvious details
Offline Kalvin
  • Embedded SW/HW.
« Reply #3 on: December 10, 2017, 05:22:27 pm »
Don't be too hard on yourself. Been there too :)
