Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
LTC3901 simulation in LTspice malfunctions (synchronous rectifier controller)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LTC3901 simulation in LTspice malfunctions (synchronous rectifier controller) (Read 842 times)
ocset
Super Contributor
Country:
on:
December 31, 2019, 01:49:02 am »
The attached is a LTspice simulation of a full bridge with synchronous rectifiers using LTC3723 and LTC3901 . (LTC3901 is a sync rect controller)
If the 2:1 signal transformer has Lp = 10mH, then the sync rect drive malfunctions. If I increase LP of the signal transformer to 11mH (keeping the 2:1 turns ratio), then it functions properly.
(The signal transformer feeds the SYNC pin of the LTC3901)
Why is it malfunctioning?
The Sync pin waveform on the LTC3901 looks fine when LP=10mH…so why does it malfunction?
LTC3723 datasheet:
https://www.analog.com/media/en/technical-documentation/data-sheets/372312f.pdf
LTC3901 datasheet:
https://www.analog.com/media/en/technical-documentation/data-sheets/3901f.pdf
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
