Author Topic: LTSpice - creating a custom model - VDCS  (Read 5276 times)
Offline daqqTopic starter
  • Country: sk
    • My site
« on: May 21, 2015, 11:36:20 am »
Hi guys,
I need a part put into a simulation in LTSpice. I've got the voltage vs current characteristic, it's very nonlinear, with ups and downs. Ideally I'd enter a table with known points and interpolate between them.
I found the Voltage Dependent Current Source part, which seems ideal, expecially in the lookup table mode. But I can't find any examples on its use, entering it or anything else. Could anyone please provide me with an example of a Voltage Dependent Current Source being used for such a purpose in the LTSpice format?
Gxxx n+ n- nc+ nc- table=(<value pair>, <value pair>, ...)
Or anything else would be very helpful.
Thank you,
Offline IconicPCB
Re: LTSpice - creating a custom model - VDCS
« Reply #1 on: May 22, 2015, 02:25:14 am »
Hello Daqq,
I recommend to You LT Spice yahoo groups.
Very knowledgeable mob. Plenty of examples and plenty of helpful people.
https://groups.yahoo.com/neo/groups/LTspice/info
  • Country: sk
    • My site
« Reply #2 on: May 22, 2015, 07:09:44 am »
Thanks, found my answer there.
For others:
To create a lookup VDCS place your part, then in its properties table enter the line Value to be in the following format:
table( -1, 3, 0, 2, 1,-1)
This would be a part where you know that @ -1V across the input terminals of the source you have 3 Amps, @0V 2 Amps and at 1V you get -1 Amps.
