Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
LTspice Inductor current not symetrical around zero
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LTspice Inductor current not symetrical around zero (Read 1573 times)
Faringdon
Super Contributor
Country:
on:
September 05, 2021, 07:42:12 pm »
I am pulsing +5v/-5v across an inductor, both saturable, and fixed, but my current is not symetrical around zero.
Do you know why not?
Logged
'Perfection' is the enemy of 'perfectly satisfactory'
Ian.M
Super Contributor
Re: LTspice Inductor current not symetrical around zero
Reply #1 on:
September 05, 2021, 08:28:10 pm »
The .tran startup option has no effect as you have no DC sources.
Your source does not have a symmetrical waveform
- fix it!
.tran uic forces all inductor currents to start from zero. Therefore if you don't want a startup transient you must start the waveform at a point in the cycle where the inductor current would be zero (after many cycles).
Try:
Code:
[Select]
PULSE(-5 5 25u 100n 100n {50u-100n} 100u)
* See my comments here:
https://www.eevblog.com/forum/projects/where-is-my-error-in-this-ltspice-simulation/
Logged
Faringdon
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
