Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
LTspice: THD error list to FFT display
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LTspice: THD error list to FFT display (Read 1582 times)
Sylvi
Regular Contributor
Country:
on:
November 10, 2018, 12:46:14 am »
Hi
I use LTspice for circuit simulations and THD tests. Is there a way to convert the data of the error log showing the amplitude of the ten harmonics into a spectral or FFT display?
Actually, I know it is done but how?
Thanks
Logged
SiliconWizard
Super Contributor
Country:
Re: LTspice: THD error list to FFT display
Reply #1 on:
November 10, 2018, 01:25:42 am »
You can get FFT display from the waveform viewer: right-click -> pop-up menu -> View -> FFT
Then you can select the waveform you want to perform an FFT on and additional FFT options (window, nb of points...)
Logged
Sylvi
Regular Contributor
Country:
Reply #2 on:
November 10, 2018, 05:58:03 am »
So simple!
Thanks
Logged
SiliconWizard
Super Contributor
Country:
Reply #3 on:
November 10, 2018, 11:49:53 pm »
Quote from: Sylvi on November 10, 2018, 05:58:03 am
So simple!
Thanks
Don't forget to select an appropriate FFT window depending on your needs, as the default is no window (thus a rectangular window) which would be appropriate only if you dealt with an integer number of periods of signal, which is rarely the case.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
