Author Topic: LTSpice with FRA  (Read 4924 times)
Offline MarkTopic starter
LTSpice with FRA
« on: January 06, 2023, 05:50:13 pm »
Just a heads-up that a beta version has been released with a new frequency response analyzer component
https://groups.io/g/LTspice/message/140962
https://LTspice.analog.com/download/17.1.4/LTspice64.msi
This link also works, although I haven't installed this install yet:
https://LTspice.analog.com/download/17.1.5/LTspice64.msi
The following users thanked this post: Warhawk, Ian.M, RoV
Offline SiliconWizard
Re: LTSpice with FRA
« Reply #1 on: January 07, 2023, 09:14:06 pm »
That's nice, if only they could fix the waveform viewer bugs first before adding new features though. ::)
Offline Ian.M
« Reply #2 on: January 31, 2023, 10:33:41 am »
Offline robint
« Reply #3 on: February 20, 2023, 12:19:41 pm »
Hi
LTspice 17.1.6 is out of beta!
https://www.eevblog.com/forum/eda/ltspice-from-29th-jan-2023/
I hope Im not breaking rules here, but as a noob to this poard, i think ive posted my topic in the wrong thread. i am hoping a MOD will pick up on this and direct to the proper thread
heregoes
https://www.eevblog.com/forum/chat/ltspice-polarise-resistor-shock/msg4712984/#msg4712984
its all about polarised resistors :-DD
A little knowledge is a dangerous thing in the Lithium world
Offline Anthem
« Reply #4 on: September 30, 2023, 07:45:37 am »
I've reverted to using LTspice XVII ver 17.0.37.0 and abandoned the newer library system in the 17.1 version. The older version works fine i.m.o. and I can get my own created components from my libraries and 3rd party libraries I have inserted into my own user library file and sub-directories by just typing the first couple of letters into the component name search window and  it go right into the sub-directories to reveal the options.. In the 17.1 version it will not reveal sub-directories in the menu and one has to explicitly place them in the control panel and when searching for them you have to explicitly open the drop-down list in the library one has added where you added the component.
While I appreciate the free LTSpice from Linear very much, the newer version/s is not nearly as versatile as the older one.
The frequency response analyzer sounds interesting but its native FFT analyser and its trace expression editor is pretty good for me with its two line cursor info that it supplies, by double clicking on the variable name in the plot curves.
