Hello everyone.
I need some advice.
I want to build a mixed-signal circuit, and I'm thinking to use a modular design approach, i.e., having different PCBs that perform different things, interconnected between them via cables.
This system should have a digital board where the microcontroller, ADCs, DACs, display and some buttons are located, and several analog boards (say 2) where signal processing is involved.
I would like a modular design for this project because if there is a need for a change in one portion of the circuit, I have only to swap the old PCB with the new one instead of having to redesign the whole PCB.
I studied a bit about EMI and related stuff and I also watched the recent videos of Robert Feranec about this topic.
In particular, in a video where he talked about ground in PCBs, its cohost, Rick Hartley, said that splitting grounds between analog and digital portion of the circuit can be dangerous and usually a potential source of EMI problems.
Now, considering that I'm not a very experienced engineer in this topic, how should I arrange this modular design to minimize this sort of problem?
Is the modular approach a bad idea?
Thanks
