Generally I would agree that marking parts is easy but the Datasheet given for this header is almost unreadable with very poor dimensions given. If I have to end up making it from scratch I will but I was hoping to for go that and see if anyone already designed one. I might be able to get away with a 0.5 pitch 24 pin FPC connector from the IPC connector library but I'm not entirely sure.
Thanks
Docmur
