Author Topic: Moving component on Altium designer  (Read 11254 times)
Offline yokoTopic starter
« on: October 15, 2013, 05:35:35 pm »
Hi there,
On Altium Designer ( PCB editor ) Sometimes we want to move component and we want the track follow the component, How to do that ? This tips can save many time.
Thank's.
Offline David_AVD
Re: Moving component on Altium designer
« Reply #1 on: October 15, 2013, 08:27:00 pm »
You can set an option to "drag connected tracks".  It's in Preferences > PCB Editor > General > Other > Comp Drag.
« Reply #2 on: October 15, 2013, 08:46:50 pm »
Ok I have set this option but nothing change, always the component is moved without the track. No idea why ?
Offline tszaboo
« Reply #3 on: October 15, 2013, 09:13:17 pm »
After that, you still have to use the "move" menu for it. "M" "C" should do it. Hovewer, the results are ridiculous, it completely ignores 45/90 degree, and you are better if you just delete the whole section and redraw it. It is a weak point.
But hey, we have a useless embedded section!
« Reply #4 on: October 15, 2013, 09:20:15 pm »
Ok now it work. For the weak point I expected that. Thank's.
Offline Nerull
« Reply #5 on: October 20, 2013, 04:17:47 pm »
Hold down control while dragging. Sometimes it works, sometimes it just makes a mess.
Offline David_AVD
« Reply #6 on: October 20, 2013, 08:46:37 pm »
Holding down CTRL while (left) dragging a component doesn't have any (added) effect when I try it.   :-//
