For a while, I have been a follower of ShrimpingIt (
http://start.shrimping.it/) and their incredibly simple design for using and programming an Atmel 328p, from the Arduino IDE.
I'd used genuine Arduinos previously, but was looking for something more light-weight in order to build into and around other prototypes. The ShrimpingIt design was simple and reliable, with only a handful of components and a schematic that any newcomer electronics engineer/hobbyist/maker could understand (
http://shrimping.it/blog/shrimp/shrimpduino_schem/).
Building this circuit on breadboard/stripboard was easy, and using an usbasp programmer I could quickly program the microcontroller 'core' for whatever I was creating. However, creating and tearing down a breadboard circuit many times can get annoying, and I wanted something more permanent on a PCB.
So I got to grips with Eagle putting in the schematic and creating my PCB. For others looking to do this for the first time, I used YouTube A LOT (
https://youtu.be/1AXwjZoyNno) to help me come to terms with all the options/buttons/decisions. I learned all about 'nets', 'vias', and other things that come with moving a schematic from paper onto a PC.
From Eagle I was able to easily export the Gerber files using the CAM Processor and put them into a zip file ready to send to a manufacturer. I'd also recommend getting yourself a Gerber Viewer from somewhere too (lots of free ones around) so that you can check the files/layers/dimensions / drill-holes before you submit it!
I'd had one PCB made previously, and it was a success, so I chose PCBWay again, based in China for my fabrication. I know they get mixed reviews on this forum, but they do offer cheap postage and 10 pieces of 100mmx100mm board for only $5. It was simple to get an account and to upload the Gerber files (in a zip) to them. There were lots of choices for holes/vias/silkscreens / soldermask etc - but I chose the most simple options, as I'm still fairly new to this. As always Customer Service was excellent - they quickly reviewed and approved my version 2.0 design. I'm based in the UK, and chose HK Post for my postal method (it was the cheapest, as I was in no hurry). The tracker let me keep up to date with how the fab process was going (took 2 days), and to see when it was put in the post.
I was again very pleased with the outcome. Great boards for me as a hobbyist.
I noticed one design flaw (my mistake!) that I had planned for 4 pin Omrom tact switches, but I only had the 2-pin SPST in my drawers - so that's why the Arduino reset switch is a little offset.
Below are some pictures of the board and it finally assembled. Happy to answer any questions from other hobbyist/makers so are looking to make their first ventures into PCB fab. I may ever be brave and try SMD next...
