Author Topic: OrCAD 17.2 latest hotfix?  (Read 4087 times)
Offline hammyTopic starter
« on: September 15, 2020, 04:40:07 pm »
I'm struggling with problems after updating Windows 10 regarding USB-Dongle and license server.  :scared:
Does anyone have access to the cadence download section?
Please, what is the latest hotfix version for OrCAD 17.20? Was there an update for "Cadence License Manager v12.08-s001"?
Any help is highly appreciated
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: OrCAD 17.2 latest hotfix?
« Reply #1 on: September 18, 2020, 04:06:30 pm »
I am not sure what the latest hotfix is because we migrated to 17.4.
The last hotfix for 17.2 we have on our internal network is Hotfix_SPB17.20.057_wint_1of1
On my new laptop i did have install issues with the dongle and license manager.
Go through the regular license manager install, it will fail trying to install dongle driver. Go to gemalto's site and get the latest sentinel LDK Run-Time (HASPUserSetup). Run that and install. Restart your PC and then you will need to start the license manager service manually. (winkey + r, services.msc >> find "Cadence License Manager" make sure the startup is set to automatic and then right click and press start.
Allegro should now open!
“They Don’t Think It Be Like It Is, But It Do”
The following users thanked this post: hammy
« Reply #2 on: September 19, 2020, 09:18:31 am »
Heureka! Thank you Pseudobyte.  :-+
Offline Pseudobyte
« Reply #3 on: September 21, 2020, 05:30:06 pm »
Oh and i wrote a script to restart the license server when you forget to boot up with your dongle installed. Save it as a .bat file. The UAC stuff is just for getting administrative privileges because to manage services you need to be elevated.
@echo off
:: BatchGotAdmin
REM  --> Check for permissions
>nul 2>&1 "%SYSTEMROOT%\system32\cacls.exe" "%SYSTEMROOT%\system32\config\system"
REM --> If error flag set, we do not have admin.
if '%errorlevel%' NEQ '0' (
    echo Requesting administrative privileges...
    goto UACPrompt
) else ( goto gotAdmin )
:UACPrompt
    echo Set UAC = CreateObject^("Shell.Application"^) > "%temp%\getadmin.vbs"
    echo UAC.ShellExecute "%~s0", "", "", "runas", 1 >> "%temp%\getadmin.vbs"
    exit /B
:gotAdmin
    if exist "%temp%\getadmin.vbs" ( del "%temp%\getadmin.vbs" )
    pushd "%CD%"
    CD /D "%~dp0"
net stop "Cadence License Manager" && net start "Cadence License Manager"
« Reply #4 on: September 21, 2020, 10:54:39 pm »
Oh and i wrote a script [...]
Cool, thank you.  :-+
Offline Evan.Cornell
« Reply #5 on: September 25, 2020, 02:13:00 pm »
I have a node-locked license (no USB dongle) and have found that occasionally I need to restart the Cadence license manager service after a windows 10 reboot. Not sure of root cause.
