Author Topic: Orcad Competitive Upgrade - Hot deal happening now!  (Read 4520 times)
Offline nctnico
Re: Orcad Competitive Upgrade - Hot deal happening now!
« Reply #25 on: March 16, 2019, 01:03:38 am »
I have my own component database which is tied into Orcad's CIS component. You don't want random components (symbols, footprints) in your design.
Being able to put something together quickly may seem like an advantage but in the long run you'll want to create your own symbols and footprints for consistency and readability. For example: what is often missing on connector footprints is the outline of the mating connector and/or the direction in which the wires or mating connector are plugged into a connector.
« Last Edit: March 16, 2019, 01:07:11 am by nctnico »
Offline mstevens
« Reply #26 on: March 16, 2019, 02:52:36 am »
Yes I get that but to get in all the parameters for the component say like the attached is as simple as looking up the component in a supplier search window then clicking import; at least for AD 18 and prior. I think in v19 it is as easy as searching and then placing the component. But the first involves manually creating the footprint and schematic symbol. Once the sch symbol is created the just import all those parameters. Is something like this even possible in Orcad? If it is it is elusive.
« Last Edit: March 16, 2019, 02:56:05 am by mstevens »
Offline nctnico
« Reply #27 on: March 16, 2019, 12:02:27 pm »
The Orcad CIS component management system can get data from several suppliers. I have never tried it though.
Offline HalFET
« Reply #28 on: March 17, 2019, 01:34:31 pm »
First of all I have used Orcad STD (DOS) and Capture (Windows) for over 25 years at various companies. In the Netherlands Orcad has a strong user base. Previously I have used Orcad Layout to create PCB designs but that has been discontinued for several years now.
And this is the part that makes people biased. I've drawn PCB designs (multi-layer flex) in AutoCAD, and for me that's perfectly ok because I've been an AutoCAD user for about 15 years now. I'll probably do it quicker in AutoCAD than many folks in . But that doesn't make it good advice for other people.
I think Altium has more eye candy where Orcad is more geared towards functionality.
I'd say Altium is more intuitive to the beginning user. I managed to get a PCB design out of Altium without reading the manual, for OrCAD I vividly remember needing an actual book to get a PCB out of it.
I think the biggest differentiator between the two packages is that Orcad has a signal integrity simulation package included.
https://www.altium.com/video-altium-presents-signal-integrity
https://techdocs.altium.com/display/ASIAE/Signal+Integrity+Analysis
For me a big plus of Orcad is that the PCB package runs on Linux natively. So far I have managed to get going by using on-line resources like instruction videos and fora.
I consider this the main disadvantage of Cadence and Mentor Graphics software, I have to use an operating system that doesn't "just work". On Linux I always find myself fighting the OS more than working on the actual task. There's always a hardware interfacing issue, the driver is never quite working without glitches, multi-screen support is lacking, ...  Windows has its flaws *cough* Windows Update *cough* but when I turn on my computer in the morning when arriving at the office I can say with some certainty that it's going to start up and that I'll be able to get started.
Ultimately there is not much difference between the packages.
Usability and bugs are major differentiators, Cadence lost all credit on that metric.
One of my customers choose Altium because they wanted to exchange designs with other companies which happen to use Altium. Without that the choice could have just as easely swung the other way because Orcad is cheaper.
Yes, Altium costs more, but licensing of OrCAD ain't always that convenient either. Like I'm fairly certain the way we used our Altium license would have been entirely illegal if we had used OrCAD instead at my last job.
At one employer I have used Altium but I needed the manual on my lap to get started on a schematic. Nothing was intuitive to me. It is also slow. And there is one thing I really hate about Altium; the default font for the pin names and labels: 'Times'. Who uses that as a default? It becomes completely unreadable when printed small (like you'd do with a schematic). It can be changed but most designers don't bother.
I'll grant you that you do have to change the fonts, but there are ways to do that quite quickly. But I found myself going to a library and needing a physical book to get OrCAD to work about a decade ago. Sure, they improved slightly in the meanwhile, but it's honestly not intuitive at all. OrCAD somehow manages to be less intuitively usable than CATIA, which is an impressive feat of software engineering.
Offline nctnico
« Reply #29 on: March 17, 2019, 01:53:03 pm »
It is interesting to read that your Linux and Orcad problems are my Windows and Altium problems  :-DD (and let's leave it at that right here right now). I'm not judging or disagreeing; I value the different perspectives.
Other than that it seems it depends greatly on your past experiences and personal taste which package (Orcad or Altium) works better for you. I hope we can agree that the functionalities and capabilities are largely the same. I can't really comment on differences in productivity.
« Last Edit: March 17, 2019, 01:55:41 pm by nctnico »
Offline asmi
« Reply #30 on: March 17, 2019, 04:33:53 pm »
LOL you got it backwards. Orcad is yet to crash once on me in 1.5 years of me using it, while Altium is well known for crashes and bugs. Check the Altium subforum to get all the proof you need :-DD
Orcad Professional is waaay cheaper than Altium yet it contains pretty much all you even need to make modern boards. And yes - unlike Altium, with Orcad you get SI tools that are actually usable :-DD
Offline blueskull
  • Country: cn
  • BA7LKP
« Reply #31 on: March 17, 2019, 05:46:14 pm »
I do have to say that Altium is buggy. I've been using their software since 99SE, and some of their bugs lived to this very day.
Offline mstevens
« Reply #32 on: March 17, 2019, 07:31:15 pm »
Candence obfuscates the real cost of its packages by breaking them into pieces. Everything that Altium can do is in Altium. With OrCAD if you want spice simulation you have to purchase PSpice. Want advanced spice simulation you must by PSpice Advanced Analysis (AA). Want this or that... Well that and this are other packages to purchase. Everything that Altium does, you get when you purchase a license of Altium Designer. That is vey nice and not deceptive.
Yeah... A good manual, tutorial, and/or training OR ALL of the above is needed for me to work OrCAD. Nothing seems intuitive, right down to the move commands.
Is it true than one cannot open two projects in OrCAD, and copy things from one project to another?
Thanks
« Last Edit: March 17, 2019, 09:53:03 pm by mstevens »
Offline RomDump
« Reply #33 on: March 17, 2019, 09:51:32 pm »
I don't understand why you would even make the post you made. I am no liar.
Sorry if I offended you but I think there was a misunderstanding. I was just saying unknown to you is that EMA gives deals to certain individuals to generate more future sales at different prices.
I can confirm what you stated is true about the promotional deal they are currently giving. It doesn't apply to me as I don't have a competing product that I can use to trade up to Orcad Professional.
Sorry if I caused any distress to you.
RomDump
Offline mstevens
« Reply #34 on: March 17, 2019, 09:57:25 pm »
Thanks. Sorry, I am a little over sensitive when I feel people are misrepresent me; it has been done to me far too many times in the past; so I apologize about blowing up like that.
Offline RomDump
« Reply #35 on: March 17, 2019, 10:08:28 pm »
If you want a crash course and not spend a bundle try Kirsch Mackey Udemy Orcad Course.
Pretty much the same content that EMA training course. Kirsch Mackey also has a Youtube channel and a Website that has more advance tips.
RomDump
Offline HalFET
« Reply #36 on: March 18, 2019, 01:58:52 pm »
Last time I used OrCAD (which has now been more than three years luckily) it didn't directly crash on me, other Cadence software took care of that bit. But that's the beauty of it, it only managed to output entirely bugged gerber files after it was running for more than a few days. Took a while until we figured that one out.
It's way cheaper in some circumstances, in others Altium's licensing policy is far more lenient. I recommend you read the license agreement very well if you're a small company. If you want to run it by the book you might need more than one license.
And I never worked with more than one design at a time with Cadence software, so no idea about that mstevens. But this is honestly my main issue with any Cadence software, there's no decent built-in tutorial. If I open up the Altium documentation I know I'm going to find an up-to-date explanation on how to do something, in the case of Cadence you might find an entry from 1992 for some DOS version of the software. Just ask for a trial license and check if it's right for you before you buy it, and read the small letters in the license agreement.
Offline mstevens
« Reply #37 on: March 18, 2019, 11:30:27 pm »
I meant to mention that I got OrCAD Pro with CIS and CIP for a base price then added PSpice for just a little more. Not only did I get an AMAZING price but I also got a PERPETUAL license.
Offline blueskull
  • Country: cn
  • BA7LKP
« Reply #38 on: March 19, 2019, 03:09:07 am »
Update: I was told that EMA can't give me international license waiver, and Fred told me he will ask his boss to give me a guarantee letter that EMA will absorb all potential litigation cost should Cadence China gets me into trouble in future. I don't think EMA's mgmt will approve this though. So the "no geo license lock" thing I was told on the phone is probably just BS pulled from the blue.
Offline kaz911
« Reply #39 on: March 19, 2019, 09:33:11 am »
Salespeople are salespeople.... They will promise they world and deliver a lot of hot vapor.
Offline blueskull
  • Country: cn
  • BA7LKP
« Reply #40 on: March 19, 2019, 11:40:02 am »
As for Altium crashing, well, it happened today on me.
I think I messed up with VM settings and I actually gave it only 2GB of RAM for whatever reason, and AD naturally complained about insufficient RAM, which is okay.
What's not okay is that it crashed right after the error message box. I don't think this is an Altium issue though. The runtime library crapped out.
So Borland has some really big issue managing memory. If you're developing a language and compiler, WTF do you have to crash after a malloc or LoadLibrary fail is out of my understanding.
If Altium wants to be a real first class software, it has to ditch Delphi and go 100% C#. This current half breed language isn't going to work for them well.
Offline NANDBlog
  • Current job: ATEX certified product design
« Reply #41 on: March 19, 2019, 12:04:46 pm »
TBH, i find this bullshit really unacceptable for a professional tool:
I've used it for a year, then I told my manager that we are buying altium. Seriously, this is a software, where I had to go and do a google search and download a guide on how to place a via.
Yeah. If you can spend that much on a software, you can afford a Windows workstation for it with ECC ram and professional grapics card. Most people complaining are running a cracked license on a pc that is below the minimum system requirements.
Offline mstevens
« Reply #42 on: March 19, 2019, 12:53:31 pm »
Altium Designer 18 and later are written using C#; so it is true 64-bit. Delphi is no longer used.
« Last Edit: March 19, 2019, 12:58:10 pm by mstevens »
Offline blueskull
  • Country: cn
  • BA7LKP
« Reply #43 on: March 19, 2019, 02:15:13 pm »
Not true. Many of its components are C#, but X2 and some of its core libraries are still Delphi. Delphi is 64-bit now.
Offline blueskull
  • Country: cn
  • BA7LKP
« Reply #44 on: March 19, 2019, 02:17:59 pm »
Altium document specifically asks for gaming cards as it doesn't use OpenGL.
I have a Windows laptop, an i7 X1 Carbon 6, for office use. I use an i7 2018 Mac Mini at home due to the stability. It doubles as my home-lab server running a number of machines (PnP, CNC, 3D printer) and services (Samba, WINS, HTTP test bed).
Offline ehughes
« Reply #45 on: March 20, 2019, 12:51:36 am »
I got a VERY good deal; I don't dare mention the price. You should call Fred at 585-334-6001 x124 and tell him Melvin sent you. He is eager to sell!!
Sorry, bullshit click-bait alert.    "I don't dare mention the price"  are trigger words meaning someone is full of shit or getting an offer to spam in exchange for a better deal.   If you are truly in the no bullshit zone then just say the real price.
Offline mstevens
« Reply #46 on: March 20, 2019, 01:14:13 pm »
You call BS. I call you an idiot! Someone in this thread already confirm that the deal exists! Either you want to purchase or you don't. If you want to and don't because you want the price I got but are scared to call and negotiate then it is your loss.
For those reading this, the deal is legit. It is my belief that companies need to make money to stay in business. At the price I purchased, I don't think EMA Designs/Cadence made money. I would not subject a salesperson to a flood of people off whom they could make no money.
ehughes don't say someone is BS unless you have the proof to back up your assertion. Have you any proof that my claim is BS? No you don't, you can't have any; because I have an invoice to prove my claim. So, I know you don't have any proof to justify your assertion.  You're an idiot!
Folks if you want a good deal on a seat of Orcad, call Fred 585-334-6001 x124, and tell him Melvin sent you. Tell him you know that he can give you a good deal because "Melvin said you gave him an unbelievable deal!" …On this page https://www.ema-eda.com/products/cadence-orcad/orcad-pcb-designer-suite/pricing plus I got the OrCAD PCB Designer Professional with PSpice - New Perpetual License with CIS and CIP options added. Not only did I get an incredible price, but I got great terms as well; that is why I posted this. You don't have to tell Fred I sent you; but know this if Fred knows I sent you he will know that there is a possibility that I told you what I paid so he is less likely to pull the salesman BS on you and try to get more out of you. That does happen with salespeople
Ultimately I posted because I wanted to help those who might NEED or WANT a seat.
Further, for example say I decided to do PCB design as a services employing 4 designers all using AD. I think I would not be inconceivable that the company may get a request to modify some legacy OrCAD or PADS design. Well If I could get a $10k Orcad license for say $1k and it were perpetual, I would buy two licenses and shelve them in the even that we may get such a request in the future.
I tell my wife all the time I get tools when I can get a deal on them, not when I need them. You always pay more when you NEED a tool. Example I bought a Kreg Foreman off Ebay, Brand new, from a factory outlet. I realized it was a deal. I picked it up for $320. ...I searched the other night for one and the cheapest I could find a new one was for about $450. I did ot need it at the time I purchased it but I have used it several times within a year after purchase.  This is just my modus operandi.
My initial post was not intended as SPAM, official advertisement, or to offend anyone or to get anyone to switch.
« Last Edit: March 20, 2019, 01:39:59 pm by mstevens »
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #47 on: March 21, 2019, 01:58:54 pm »
I have been receiving this promo for a while now but I couldn't yet justify spending that kind of money with a hobby. Especially since I have access to these tools at my work.
Regarding this whole price discussion, I can tell from experience that pricing of goods (especially in B2B transactions) is highly dependent on who you talk to.
My experience with both Altium and OrCAD are very similar to others, with a slight edge for me for Altium. Back in the days of heavy keyboard (or no mouse at all) use, OrCAD was king. A few years later I could tell that others were catching up, until I found and fell in love with Protel, with many successful designs back then. My attempts to get back to OrCAD were not as successful, but I am truly reconsidering it nowadays given that versions post Altium 12 have become so convoluted for my taste.
