There are several reports in the "Export->Quick Reports" submenu, but I usually use "Check -> Design Status" window because it's a single central location that allows to see current board status - things like unrouted connections, unplaced symbols, or DRC status. Click on a small green-yellow-red box to the left of category to see the list. In that list there will be hyperlinks, when you click on it the editor will be centered on area in question. It doesn't automatically zooms in or out (at least I don't know how to make that happen), but I usually zoom beforehand.
