Author Topic: OrCAD/Allegro : Aligning components in layout  (Read 2027 times)
Offline Pack34Topic starter
« on: September 11, 2018, 04:21:32 pm »
There seems to be a general alignment tool in Allegro but doesn't allow you to dictate how that alignment happens (Left, Right, Up, Down, etc).
Is there another way to do this? In Altium I would select a series of components and then edit all of their X or Y values to be the same and then hit distribute. Can the same workflow be done in OrCAD/Allegro?
Offline Neilm
Re: OrCAD/Allegro : Aligning components in layout
« Reply #1 on: September 12, 2018, 07:05:02 pm »
Highlight the components - right click on the one you want to align to and hit align. Look in the options menu for direction, alignment edge, spacing etc.  I am assuming you are running a reasonably up to date version of allegro, I use 16.x at work.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline U96
« Reply #2 on: October 16, 2018, 01:42:47 pm »
for this to work, make sure you are in the 'Placement Edit' environment.  otherwise you do not have this option in your menu
