They call "pan" to the act of navigating through the layout.
Let's imagine that you are seeing a part of your layout with a certain amount of zoom. Without zoom out, you must be able to navigate right, left, up or down.
The problem is that, to achieve this, I would prefer to use the keyboard arrows and not the middle wheel mouse button.
I tested the INSERT key, and nothing happens.
There is another shortcut list beyond the showed on the constraint manager -> setup -> shortcuts?
I know that ctrl+B fits the board on the screen, but I do not find more useful shortcuts...
Its impossible to route and, at the same time, moving the design with the mouse.
When you reach the end of the screen, the design/layout does not move, so you need to use the middle wheel mouse button to move the design, but then you will pass over other traces. It's not very practical...
Thanks for your time!
