Author Topic: PADs standard questions  (Read 1351 times)
Offline FaringdonTopic starter
« on: July 06, 2021, 04:30:06 pm »
When creating a symbol and you want to "enclose" the rectangular silkscreen top layer closely around the component...then how do you move the silkscreen line without it disappearing and becoming an extremely thin white line whilst you move it?
Also, what layer do you usually put the component courtyard on in PADs standard?
(as you know, the component courtyard  shows the maximum perimeter of the component so that you can avoid collisions.)
« Last Edit: July 06, 2021, 04:41:29 pm by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
Offline CalMachine
  • Metrology Nut
Re: PADs standard questions
« Reply #1 on: August 30, 2021, 05:03:15 pm »
One way is to press Alt+Enter to bring up the line properties.  Then type in x1,x2 and y1,y2 coordinates of the line to get it exactly where you want it.
All your volts are belong to me
