Author Topic: PADS Standard vs. PADS Professional  (Read 1434 times)
Offline Feynman
« on: June 08, 2019, 01:08:00 pm »
Hi there,
for our small PCB design team (4-5 engineers plus maybe 1-2 students temporarily) we are planning to change to a new PCB tool (moving away from EAGLE 7.X).
Since some of our engineers already have had experience with it, we are having a closer look into Mentor PADS (other alternatives are Altium and Pulsonix).
I'm already in contact with our local sales representative, but I'm looking for some first hand opinions :)
There seem to exist two variants of PADS: One being "Classical" PADS, now called "PADS Standard (Plus)", and the other one being "PADS Professional".
According to our sales representative, classical PADS and PADS Professional are basically two different systems. PADS Professional seems to be the new tool which Mentor will focus on.
How is your general opinion on either classical PADS or PADS Professional? According to our engineers and some google research classical PADS is rather old and clunky and has some weird quirks (which PCB tool doesn't? ;) ).
How does PADS Professional compare to classical PADS?
How difficult is the transition from classical to professional PADS? Are they really two entirely different systems?
Thank you in advance :)
Regards,
Feynman
Offline T3sl4co1l
    • Seven Transistor Labs
Re: PADS Standard vs. PADS Professional
« Reply #1 on: June 08, 2019, 01:25:45 pm »
I never got a feel for how PADS is supposed to work.  It doesn't seem to "flow".  That was on, um, PADS 13 or so I think?  Or wait, maybe it was 8.3 or something?  I don't remember the versions anymore.  Also there were different variants back then too, I think that was PADS Logic.  Whatever that's equivalent to today, I guess.
Anyway, I was able to do things, but either I was unable to figure out the proper flow, or I blocked myself from being able to see it (or, there simply is no "flow" to it, and it really is just that bad).
I "grew up" on Altium, so the second possibility is most likely, in all fairness.
Are you concerned much with format compatibility?  I don't know if PADS can import Eagle (but, wouldn't be surprised if it does).
Seven Transistor Labs, LLC
The following users thanked this post: Feynman
Offline Feynman
« Reply #2 on: June 08, 2019, 05:39:32 pm »
This was "classic" PADS then, I guess. I know someone who worked with "PADS Logic 9.3" and "PADS Layout 9.3" have a year ago . His experience was similar to yours :D
Fortunately there is no need for an import feature, since we have infinite EAGLE 7.x licenses that allow us to fix/modify our old boards in the future.
« Last Edit: June 08, 2019, 07:10:26 pm by Feynman »
Online Ysjoelfir
« Reply #3 on: June 10, 2019, 01:30:42 pm »
I had the "chance" to work with all four of the mentioned tools. Eagle was quite nice but restricted at some times. Moved away from that to switch to Altium (better: Circuit....maker, studio, whatever that 500$ thing is called. I always forget.), the transition was really smooth and easy.
PADS was the tool we used at work. Awfull, I can totally support the lack of "flow" Tim mentioned. We discarded PADS for Pulsonix, which is.... ok-ish, but not nearly as good as Altium. I prefer the smooth keyboard controll instead of having to click on every command I want to perform. Also I prefer the rules- and stackup system from altium over the "technology" system from pulsonix as well as I way prefer the intuitive, easy to create libraries from altium.
At work we decided for Pulsonix over Altium because, well, basically because altium didn't bother to send a competent sales representative for only 10 seats.
Greetings, Kai \ Ysjoelfir
Offline Feynman
« Reply #4 on: June 14, 2019, 04:24:16 pm »
Was this classical PADS or PADS Professional? Sounds a lot like classical from all I know so far :D
Online Ysjoelfir
« Reply #5 on: June 14, 2019, 09:38:58 pm »
It was just called "PADS", so... no clue.
Offline CadenceAE
« Reply #6 on: June 26, 2019, 12:18:38 pm »
if your debating PADS VS Altium you might also consider OrCAD.  When it comes to the mid tier of PCB design tools those are the three most companies use.
https://www.orcad.com/
Offline dzseki
  • Country: hu
« Reply #7 on: June 26, 2019, 02:02:28 pm »
At work we have PADS 9.3 (and 3.5 too) working on legacy projects, but for new ones we use Altium 18 (earlier 9 and 13 too). I am curious what do you mean by „design flow”? For me Altium and PADS are equally usable, they are different in many ways, of course. Also there are some things in wich I like the PADS approach more and in others the Altium way.
But I don't do cutting edge designs so to say, no high density, etc.
Offline Jester
« Reply #8 on: June 26, 2019, 09:03:53 pm »
I have used Pads, Orcad and Altium.  IMO, Altium is by far the best, Orcad was pretty decent, Pads was brutal.  I recall reading a review that pretty much described my Pads vs. Alitium experience..... something about Pads being about as effective as pissing the design into a snow bank.   Found it, here it is https://offlogic.wordpress.com/2009/08/12/why-does-mentor-graphics-suck-so-very-very-much/
« Last Edit: June 26, 2019, 09:14:58 pm by Jester »
Offline dzseki
  • Country: hu
« Reply #9 on: June 27, 2019, 06:50:02 am »
I have to add I've never used the DxDesigner, instead , the old fashioned PADS Logic/Layout/Router approach, that works pretty well IMHO, not like stated above.
Offline Feynman
« Reply #10 on: June 30, 2019, 10:15:17 pm »
What exactly is DxDesigner? The former schematic capture of PADS Professional? I just installed a PADS Professional trial and the schematic capture is called "PADS Designer".
This PADS/Mentor stuff is really confusing...
Offline gasmeter
« Reply #11 on: July 01, 2019, 10:22:11 am »
Hi
I use pads standard and the difference is just that some features restricted.
The only thing in the differences I think that would help you from a team point of view are  the centralised libraries.
You have two schematic options with pads.
Standard pads logic or the more modern dx designer.
There are lots of videos on youtube explaining.
I think most people will agree that what matters with a cad package is the time and effort you have invested in it.
If its altium or pads both will give you a good design environment.
Once you commit to you it should be for the long term !
Peter
« Last Edit: July 01, 2019, 11:58:20 am by gasmeter »
Offline Feynman
« Reply #12 on: August 18, 2019, 07:26:39 pm »
Just to shed some light on the matter:
After evaluating the tool, "PADS Professional" has very little in common with "classical PADS" or "PADS Standard/Plus" as it is called now. It is a completely different tool.
However, PADS Professional is very similar to Mentor's high-end package "Xpedition". PADS Professional is more or less an "Xpedition light".
Offline chrisl
« Reply #13 on: August 18, 2019, 07:52:13 pm »
This is correct.  PADS Standard/Plus is the original PADS flow.  PADS Professional is the water down version of Xpedition PCB.
They are completely two different tools and cannot even open each other's design files - although both programs save their design files as *.PCB.
Offline ddavidebor
    • Fermium LABS website
« Reply #14 on: August 19, 2019, 05:48:16 pm »
Isn't PADS... Reeeeeeally old?
Davide Bortolami,
Fermium LABS srl
Offline gasmeter
« Reply #15 on: September 05, 2019, 08:08:22 am »
Apologies
I was confusing Pads standard and pads plus.
Peter
Offline Feynman
« Reply #16 on: September 07, 2019, 06:38:47 pm »
Just a quick update: We opted for Pulsonix. Price/Performance is really decent and the interface is intuitively enough too find out most stuff by playing around.
The following users thanked this post: gasmeter
