Author Topic: panel breakoff  (Read 1922 times)
Offline Alex EisenhutTopic starter
  • Place text here.
panel breakoff
« on: June 04, 2017, 03:32:56 pm »
What's the best approach to panelize 8 mil Rogers boards? The usual breakoff tab for your typical fiberglass 62 mil thick PCB just breaks apart at the slightest touch...
yup, I made a booboo.
So I'm thinking of putting a bunch of 10 mil unplated holes around the board so it looks like a sheet of stamps.
That should be solid enough yet easily torn apart?
Offline Mattylad
Re: panel breakoff
« Reply #1 on: June 04, 2017, 08:21:22 pm »
Use IPC mousebyte tabs, they have a hole in them to make breakoff easier.
Matty
CID+
Offline suku
  • Country: hu
Re: panel breakoff
« Reply #2 on: June 09, 2017, 08:21:02 pm »
properly designed mousebytes are the most controlled and professional way of doing this in my opinion...
