Author Topic: PCB Etching and some chemistry  (Read 14735 times)
Online TheAmmoniacalTopic starter
  • Country: no
« on: May 25, 2014, 08:03:04 am »
I just made my first PCB ever today, but also used all the hydrogen peroxide, so I need some help. Hydrogen peroxide has become difficult to acquire in the recent years, but that doesn't mean I can't get it or make it, I just need to know if it's worth it. I consider the usual ferric chloride a bit too messy to work work, as I have to do this in my room.
So the next best option from googling around is persulfate/peroxymonopersulfate/oxone, but I haven't been able to find any videos or tutorials explaining how effective this compound is as an etchant, at which concentration is it the most 'active'? Does it require heating? Does it take a long time?
Could anyone here give me an idea? The hardware store sell it in 1 kg bottles at $40 a piece.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: PCB Etching and some chemistry
« Reply #1 on: May 25, 2014, 08:08:57 am »
Yes, give it a look.  I recall it being popular in the magazines.  More expensive, but way the hell cleaner.  Anyone who thinks HCl + H2O2 is easier than FeCl3 is lying... it's stinky, highly acidic and corrosive, and almost as messy (copper doesn't stain quite as badly as iron).
And your name is, rather smelly :P
Seven Transistor Labs, LLC
« Reply #2 on: May 25, 2014, 08:11:31 am »
The persulphate requires heating to about 40C to get it to work effectively, and when cold it is a lot less reactive, so much easier to store. I used it years ago to etch in a tank, where it did a very good job pretty fast.
Offline poorchava
  • Troll Cave Electronics!
« Reply #3 on: May 25, 2014, 08:12:46 am »
You can use pharmacy grade 3% peroxide. Concentrated 30%+ peroxide is not needed (actually you need to dilute it in water or the reaction gets extremly violent)
  • Country: no
« Reply #4 on: May 25, 2014, 08:49:59 am »
The pharmacy here charge $80/L for 3% hydrogen peroxide, which is something I wouldn't/couldn't pay. Chemistry was my primary hobby before I started doing electronics, where I used to make hydrogen peroxide by dissolving sodium percarbonate in water, precipitating the carbonate with calcium chloride and filter out a hydrogen peroxide/sodium chloride mixture. This way I could get 13% H2O2 (with ~7% NaCl), that works in 'all' acidic and basic solutions.
Offline sleemanj
  • Professional tightwad.
« Reply #5 on: May 25, 2014, 09:56:42 am »
A quick check on ebay shows you can get 500ml of 35% H202 to your door in Norway from the UK for total 25 GBP, by what appears to be a business well versed in appropriate means of sending such chemicals around Europe.
http://www.ebay.co.uk/itm/Food-Grade-Hydrogen-Peroxide-35-500ml-/130543355740
Admittedly that's pretty pricey (at least here in NZ I can get a litre of 35% for nearly half that price), but it would last you a very long time - even given it's propensity to degrade, it's going to be plenty strong enough for a very long time, as long as you keep it cool and dark.
Don't throw out the "used" etchant it becomes CuCl2 etchant, just add a little H202 each etching session to keep it bright green, and if etching is slower than you'd like a little more HCl.
Since you have an interest and are experienced in chemistry, if you should want to get all technical, you can check out Adam Seychell's information which I've mirrored to a PDF here:
http://sparks.gogo.co.nz/seychell.pdf
But, I just go by eye/feel, too dark = add a cap of H202, too slow = add a cap or two of HCl.
  • Country: no
« Reply #6 on: May 25, 2014, 10:07:08 am »
That eBay store is very much legit, and I have ordered from them before once for when I needed more concentrated solutions. At that time the shipping cost was lower aswell. But for reasons I won't go into I am not able/willing to import any such thing into the country again. (Breivik/EU Regulations)
Thanks for the PDF, will have a read.
Offline LukeW
« Reply #7 on: August 13, 2014, 07:12:32 am »
Ammonium persulfate (or any of the persulfate salts really) work fine as etchants, but they do need to be heated up a bit, generally about 60 degrees C.
Temperature regulation is not critical, you can just use just-boiled water from the kettle or stove when you initially dissolve the solution and then stick the board in, and let it etch as the solution cools.
They don't stain everything like ferric chloride.
Offline con-f-use
  • Country: at
« Reply #8 on: August 13, 2014, 07:36:23 am »
You can "regenerate" (actually it's a different reaction) your spent H202 + HCl etchant by bubbling air into it. See Etching with Air Regenerated Cupric Chloride.
Actually it doesn't even need that much attention to chemistry .
Offline poorchava
« Reply #9 on: August 13, 2014, 08:29:27 am »
If one has space to make a special "etching lab", then solutions which require heating and strong agitation (persulfate, cupric chloride) may be fine. If (like me) you do not have space to do that, then peroxide + hydrochloric acid is the way to go. Mix 50ml of the solution, etch the board in 5-10 minutes and flush in the toilet. Job done. Quick and clean. Plus the reaction is exotermic, so the solution heats up itself (just don't overdo it - at higher concentrations of peroxide and bigger acid contents this gets REALLY violent). The very minor amount of copper introduced into sewers won't hurt nobody (if anything, it may slown down scale build up by a bit)
Offline con-f-use
  • Country: at
« Reply #10 on: August 13, 2014, 09:17:25 am »
[...] etch the board in 5-10 minutes and flush in the toilet. Job done. Quick and clean.
The toilet? Really? You don't eat fish, do you
« Reply #11 on: August 13, 2014, 05:13:59 pm »
Flushing it down the toilet here would be an improvement. A small amount will be rapidly diluted, and in any case the water supply has copper in it anyway from piping, and the other chemicals are used in water treatment planys in large amounts. At present the beaches are not classed as a place to swim, unless you like to swim in a septic tank. Ecoli pretty much off the scale and other stuff high enough that you can measure with your nose at 500m.
Offline rob77
  • Country: sk
« Reply #12 on: August 13, 2014, 09:37:58 pm »
are you feeding some fish-farms with water from the sewers in Austria ? I would be more worried about the industrial waste water than a 50ml of etchant with 1gram of copper in it ;)
i personally use the official waste collecting places to dispose all suspicious waste (we have those in every town), but i know very well what amount of industrial shit is disposed into the rivers. ecology is one thing... but corporate cost savings is another which always wins unfortunately :(  it's like that even in your ecological country (otherwise the Danube would be crystal clear when entering my country right ?)
don't get me wrong.. .i like the way your country is trying to be more green - big thumbs up for that  :-+  :-+  and even bigger thumbs up for the ecological consciousness of the citizens of Austria !  :-+ :-+ :-+  but let's not ignore the corporate and industrial reality ;) the industrial waste is killing the nature, not the minor waste which comes from a misbehavior of individuals.
Offline PepeK
  • Country: sk
« Reply #13 on: August 13, 2014, 09:52:35 pm »
Is it really so complicated and expensive to buy a peroxide ? In my country, absolute no problem, every big shop selling paints, thinners etc. have 500ml bottle of 30% for approx 1 euro. The same for a hydrochloric acid, 32%, 500 ml ...
I mix 20 ml of acid + 10 ml of peroxide + 70 ml of water. Works nice, very little smell, can be done inside in a bathroom.
Offline poorchava
« Reply #14 on: August 13, 2014, 10:09:17 pm »
Here in poland Peroxide used to be stocked in any hardware store like Obi or Leroy Merlin, but people are stupid. Any container with peroxide must have a tiny hole in order to let the oxygen gas out and prevent pressure buildup. There is a HUGE sign to keep the bottle vertical, but people are dumb and they were tipping the bottle over anyway, they've burnt their clothes and such and stores resigned from selling it. Hydrochloric can still be bought as a strong flux for soldering galvanized gutters. You can also get it from chemical wholesaler (like I did) but since it's a dangerous substance, I has to give them my personal data and purpose for purchasing the chemical ("metal etching" worked just fine).
I'm buying my 30% peroxide from professional haircut supplier for about 4€/liter
Offline con-f-use
  • Country: at
« Reply #15 on: August 14, 2014, 07:38:17 am »
The industrial waste is killing the nature, not the minor waste which comes from a misbehavior of individuals.
Very much agreed. Likewise it is not really sensible to require light bulbs to have a certain efficiency when household lighting or even all lighting combined only makes a tiny fraction of the overall electricity consumption. Or to recycle, when industrial waste is the bigger problem. Or to make effort as a small developed country, when 90% of the world's population (especially China, India and Russia) don't give a shit. However, it's still NEVER okay to pollute or waste no matter the extent. Pointing that out serves to educate people. Its a culture thing. Shaming people who make a small mess, might prevent them from making a big mess later on in their lives, when they might the decision makers. A few 100 years ago it was okay in Europe to beat your children, burn people on stakes and shit on the sidewalk. Society can evolve, but it starts with education and a general consensus...
...or a big catastrophy.
« Last Edit: August 14, 2014, 07:42:27 am by con-f-use »
Offline Refrigerator
  • Country: lt
« Reply #16 on: August 14, 2014, 01:02:48 pm »
You can use copper chloride, just take your hydrogen peroxide and hydrochloric acid mix and add a bunch of copper until it becomes a very deep green, then boil off some of the water and add some more hydrocloric acid.
Here, watch this video, it should explain everything you should know.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline Cside
« Reply #17 on: August 15, 2014, 09:44:04 am »
try base pirhana (NH4OH + H2O2) or the stronger piranha (HS204 + H202). Ive used piranha in chemistry research and I promise you it will etch oxidize anything that has electroncs to strip.
It will also blow up in your face if you mix it too fast, or incorrectly.
Online westfw
« Reply #18 on: August 15, 2014, 11:03:03 am »
In the US, it's petty difficult to find peroxide stronger than 6% (aka "20 volume"; be careful what the label says.)  Normal peroxide is 3%.
Fortunately, that's just fine for making Copper Chloride etchant.
It's a FEATURE that copper chloride, ferric chloride, and persulphate, are "milder" than The "pirahna" (strong acid + strong peroxide) etchants.  Pirahna etchants are famous for dissolving organic contamination as well as metal.  You know, like skin and flesh!  (And in contact with organics, they're also prone to forming organic peroxide explosives...  Not at all a good thing!)
Offline Cside
« Reply #19 on: August 15, 2014, 11:39:25 am »
a little bit of dissolved flesh never hurt anyone!
wear gloves and use a fume cupboard, use a pipette and thermometer so it doesn't runaway from you.
Otherwise stick to sofcore 3% H2O2 and wait all day to complete the oxidation.
The real question is whats wrong with getting your pcb fabricated by any of the many cheap fab-houses? Im sure even the dodgiest company will produce superior results to a home-made etch. if its purely for experience and chemistry then I understand but otherwise???
  • Country: lt
« Reply #20 on: August 15, 2014, 12:23:10 pm »
The time is the main factor, for me i can make a PCB in three hours from print to soldering the components, but it might take a couple weeks to get them from a fab-house, it's also somewhat cheaper.
Offline Cside
« Reply #21 on: August 15, 2014, 01:04:37 pm »
That is a good reason actually.
in that case dont take my chemistry suggestion seriously unless you know what your doing you will probably blow your fingers off.
If you cannot source H.peroxide you can make it with ozone. Ozone can easily be made with high voltage so you should be able to construct a colum easy enough.
I know of no other known oxidizing agents that have been well tested and readily available. These days anything stronger than table salt is difficult to obtain without signing countless forms and proving you are not walter white or osama.
  • Country: lt
« Reply #22 on: August 16, 2014, 05:44:10 am »
Really? Well, that sucks.  :o
Here in Lithuania you can get all kinds of chemicals and no one will ask a thing. ::)
Offline akis
« Reply #23 on: August 17, 2014, 07:22:04 pm »
I use ammonium persulfate http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=161014761335&ssPageName=ADME:L:OU:GB:3160
Take 1lt of hot water (50C) add a couple of tablespoons of the white powder and you have an etching solution that lasts for a few PCBs. Etching takes place at 50C and is quite slow. Just add hot water and powder when the levels go down.
Offline N2IXK
« Reply #24 on: August 17, 2014, 07:40:25 pm »
TPTB seem to be making high strength H2O2 harder to find because of the "OMG!! Terrorism!!!" stuff. Useful for producing acetone peroxide, an easily made (but dangerously unstable) explosive compound that contains no nitrogen, and therefore can avoid detection by many explosive sniffers.
"My favorite programming language is...SOLDER!"--Robert A. Pease
