Haven't used Ferric Chloride or the other persulfates for donkeys years. Why ?
FeCl3 is too messy, expensive, hard to clean up, a bit slow sometimes.
Persulfates are waaaaaaay too slow for my needs.
6% H2O2 and conc. HCl works great in equal volumes (a little goes a long way).
Fresh mix etches in about 2 minutes.
Gentle agitation is suggested as the bubbles formed can attack your resist.
I often do prototypes in 5 thou or less widths. (photographic process).
Hardest part in these thin traces is waiting for the photoliths to arrive.
Other etchants undercut or have poor edge definition when at this scale.
The remaining green solution is a great etchant too, You can let it evaporate to a concentrated liquid or even crystalise it.
Next time add a little fresh HCl and peroxide and etch in a few minutes again.
If you need to neutralize it, add washing soda (sodium carbonate) or bi-carb soda until it stops fizzing. You end up with a solid copper salt that can be more easily disposed of and salt water.
If your solution goes brown when adding the acid and peroxide together, don't worry. It's just iron contamination in the acid - and that acts a like a catalyst !!!
Avoid doing this in your room, the fumes will attack you and ANYTHING metal.
