Author Topic: PCB layout simulation software  (Read 3677 times)
Offline xzswq21Topic starter
« on: February 02, 2019, 07:21:50 am »
Hello
Actually I have designed an analog circuit but I want to simulate the layout bcoz the circuit is precision (the frequency range is only some MHz). the circuit has some op-amps and some passive components.
Can I simulate the layout in HyperLinx? which software do u recommend me?
Thanks
« Last Edit: February 06, 2019, 07:22:46 pm by xzswq21 »
Offline free_electron
    • SiliconValleyGarage
Re: PCB layout simulation software
« Reply #1 on: February 07, 2019, 01:46:58 am »
What od you hope do extract from the PCB layout ? parasitics ? ANsoft but at MHz range ... there is not much you will learn.
Your surface cleanliness is more important. ake sure you have guards in place to stop leakages.
The following users thanked this post: xzswq21
« Reply #2 on: February 07, 2019, 07:27:25 am »
You are right.
Actually at some sensitive area I have placed some non-plated holes to blind stray capacitance and I have removed some reference plane and solder mask resin. I should reduce the stray capacitance to keep them below than 1pF.
you mean ANsoft Maxwell?
sometimes I design high speed ADC/DAC boards. I have many problems with using of 3rd party software to perform SI analysis. I have looked ur comments in other posts. u recommended pads/Allegro/Expedition/…
I don't know why I don't like Cadence's software! I checked Expedition and I found a few videos about it and I'm skeptical to use it. but about the PADS I found many professional PCB designers in "LinkedIn" that worked with PADS. what do u think?
« Last Edit: February 07, 2019, 01:58:07 pm by xzswq21 »
« Reply #3 on: February 07, 2019, 04:22:20 pm »
You are right.
Me recommending Cadence or Mentor ? Blasphemy ! Altium, yes !
if stray capacitance is a problem : active guarding. look up the Keithley handbook of low voltage low current measurement.
« Reply #4 on: February 07, 2019, 05:05:22 pm »
https://www.eevblog.com/forum/eda/mentor-vs-altium/msg516890/#msg516890
Actually I have been using Altium. but I have problem in SI analysis with Altium. have u ever converted Altium file to HyperLynx? all information will be lost so the converted file is useless.. I think I should use PADS but I'm skeptical... Altium is very convenient!
« Last Edit: February 07, 2019, 05:12:06 pm by xzswq21 »
« Reply #5 on: February 07, 2019, 07:55:14 pm »
hou much stary capacitince do u guess is placed between these pads:
it should be less than 1pF. is it a good layout? (solder mask free and many non-plated holes)
« Last Edit: February 08, 2019, 05:23:34 pm by xzswq21 »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: February 07, 2019, 08:41:42 pm »
Trying to reduce capacitance is probably a heroic, and ultimately futile, effort.
When low capacitance is required, it can be bootstrapped away, at least to some extent (e.g., Phil Hobbs did an IC test probe with something like 0.1pF equivalent, despite the probe end being much larger than 0.1pF equivalent of transmission line).  This isn't universally applicable, though.
More often, you should just design in the capacitance.  Compensate where necessary, harness where possible.
For an op-amp circuit, typically capacitance loading the inputs (especially inverting input) is compensated with capacitance from output to inverting node.
Seven Transistor Labs, LLC
Offline r0d3z1
« Reply #7 on: February 08, 2019, 01:10:17 pm »
Layout simulation is an interesting argoument, I also opened a topic about layout simulation some time ago:
https://www.eevblog.com/forum/eda/pcb-layout-full-wave-simulator-and-spice-co-simulation/msg1401815/#msg1401815
It would be nice to know what this hyperlinx can do.
« Reply #8 on: February 08, 2019, 04:34:55 pm »
Actually I have invented a new topology for a current source. I have proved the performance in theory and simulation and I defended from it. I have designed the PCB accurately and reviewed lots of books and papers to consider anything. on the other hand I have designed and built a high speed data acquisition to produce and capture the signals. I will post the reslut later.
Offline T3sl4co1l
« Reply #9 on: February 08, 2019, 04:56:31 pm »
The only "new" topology I'm aware of is the shunt CCS I invented back in 2010ish,
which I put with this description,
This revolutionary (and impressively useless) circuit is the completion of an analogy. Consider: voltage sources are available in two flavors, shunt (e.g., TL431) and series-pass (e.g., LM7805). But current sources are only available in one style, series-pass. These simple circuits complete the analogy, providing a shunt current source. In both cases, a resistor provides a current greater than or equal to the desired output current over the rated range; a current sense resistor, voltage reference and voltage amplifier (VBE and a BJT in the left example; a TL431 and differential pair in the right example) adjust a shunt current to keep the output current constant.
« Reply #10 on: February 08, 2019, 05:11:12 pm »
How much the output impedance of your current source is? tell me about the curent vs loading, linearity...
(I think you have invented a DC current source) but my curent source works within some MHz with high output impedance to give u a high resolution. in opposite to other current sources, you can follow all safety CF/BF/B for IEC60601 standard with my current source due to its excellent performance. (it uses for Kelvin probe or Tetra Polar topology). I didn't add any extra ICs but I improved the current source.
please give me DOI of ur paper.
« Last Edit: February 08, 2019, 07:49:00 pm by xzswq21 »
