Author Topic: PCB Library Expert tool query  (Read 2843 times)
Offline AdwaittronicsTopic starter
« on: June 06, 2017, 06:15:49 pm »
I am using PCB Library expert Lite 2017 version ,can anyone tell differences between the "Lite" and "Pro" versions?
What extra features are available in "Pro" version which are not there in "Lite" version?
Offline Mattylad
Re: PCB Library Expert tool query
« Reply #1 on: June 07, 2017, 05:58:01 pm »
Try looking through the pcblibraries forum.
It is well explained in https://www.pcblibraries.com/forum/free-pcb-library-expert-lite-vs-library-expert-pro_topic890.html
Basically, the pro version does everything, saves your work so you can go back and output all your footprints 12 months later to another CAD package with ease.
The free lite version is an enter and create then throw away your entry version, you want them again you enter the data again (not hard really).
The lite outputs 7351-b only, the pro can be customized.
Use the lite version to understand it, then for me for a business the pro version is well worth it in the time it will save you.
FYI I have absolutely no connection to them, just an ex user.
Matty
CID+
