Author Topic: PCB Material  (Read 2533 times)
Offline JtroTechABTopic starter
  • Country: in
PCB Material
« on: October 05, 2018, 06:45:28 am »
Hello,
See the attached Images for the reference.
Want to know the material of PCB.
Online krish2487
Re: PCB Material
« Reply #1 on: October 05, 2018, 11:12:31 am »
There.
https://en.wikipedia.org/wiki/Printed_circuit_board#Materials
You have the all the information you need ! :-)
Now, was that so hard to google that yourself.
Hope this helps.
If god made us in his image,
and we are this stupid
then....
  • Country: in
Re: PCB Material
« Reply #2 on: October 08, 2018, 11:45:26 am »
Hello,
They have mentioned list of materials.
But it is not matching with the pcb which I have.
As you can see in pic. one side is green and the other one is white.
Want to know which type of pcb it is ? What material?
Offline hv222
Re: PCB Material
« Reply #3 on: October 08, 2018, 04:50:16 pm »
Probably CEM-1 or FR4. It's green, because of solderresist layer over the board.
Online mariush
Re: PCB Material
« Reply #4 on: October 08, 2018, 05:01:59 pm »
The white or cream boards used to be FR2 and the green circuit boards used to be FR4 (fiber glass based) ... but the green is just a colorant and can be used on other types of circuit boards.
Easiest would to grab a knife and scratch the board and use a microscope to see what the board is made out of.
Offline cjurczak
Re: PCB Material
« Reply #5 on: October 15, 2018, 03:50:44 pm »
Could also be a phenolic resin material, consistency similar to many plastics, usually single sided as shown.  Tends to warp when heated to high, so it's use is limited in RoHs applications.
Offline ThomasDK
  • B.Eng. EE
Re: PCB Material
« Reply #6 on: October 19, 2018, 02:53:02 pm »
Looks like CEM-1 or 3.
