Author Topic: PCB paristic capacitance  (Read 6625 times)
Offline john23Topic starter
  • Country: aq
« on: February 26, 2024, 02:09:03 pm »
Hello, given the pcb shown below, how do i know from the route from 1 to 2 what parasitic capacitance i will get into the input of the opamp located at point 2?
Thanks.
Online iMo
  • Country: vc
Re: PCB paristic capacitance
« Reply #1 on: February 26, 2024, 02:21:30 pm »
You may a) calculate that (you have got all the data needed), or, b) your PCB design tool tells you that.
a) is a quite difficult exercise, b) would cost you an arm and a leg..
Offline metebalci
« Reply #2 on: February 26, 2024, 03:00:47 pm »
What is the solution for (b) ? an EM solver or something else
Offline metebalci
« Reply #3 on: February 26, 2024, 05:09:57 pm »
Thanks.
Does the PCB have two layers ?
  • Country: aq
« Reply #4 on: February 26, 2024, 06:53:06 pm »
yes two layers.
Offline Andree Henkel
« Reply #5 on: February 27, 2024, 08:52:31 am »
given you would know the answer, what would you use it for?
