Author Topic: pcb-rnd 2.2.0 release  (Read 5072 times)
Offline ScribblesOnNapkins
« on: January 24, 2020, 03:35:00 am »
The following is reposted from our pcb-rnd mailing list.
Hi all,
after another busy development cycle, I'm happy to announce pcb-rnd 2.2.0,
our latest stable release.
Thanks to everyone who contributed!
Project page: http://pcb-rnd.repo.hu
Release notes:
pcb-rnd 2.2.0
This version of pcb-rnd is mainly a cleanup/bugfix version with 3
notable new features. One of the new features is the extended object
infrastructure, that provides a sustainable way to extend pcb-rnd features
with new tools and objects without having to complicate the data model.
With this release the second digit of the version bumped because pcb-rnd
is entering a new era. librnd (including the hidlib) is already installed
and being used by external applications. The new 2.2.x era is about
starting to separate librnd from pcb-rnd. This effort will take multiple
development cycles.
Feature highlight:
1. extended objects (line-of-vias and dimension lines)
2. OpenEMS export: suitable for microwave filter and antenna simulation
3. STL export: yet another path to 3D
4. io_eagle: various bugfixes and improvements in the loader allows more
   eagle boards to be loaded with less glitches
5. scripting: action code upgrade allows delivering the hidlib/PCB pointer
   to actions as argument (in argv[0]) which long term makes the code
   reentrant; centralized and unified layer and layer group addressing
   (using the syntax and experiences from cam)
6. windows port: the cross compilation setup got smoother and the startup
   code more robust, removing all known windows-port-specific bugs -
   locales and parametric footprint dialog work well now
Best regards,
Igor2
