It is realistic, but it does not mean it is impossible to have longer traces. All you need is impedance match your traces and follow the guidelines for transmission line routing (no stubs, avoid vias, have solid ground planes). And any devices that can generate or receive 1 GHz would specify the impedance values, your goal is to match them to avoid reflections.
