Author Topic: pcb woes jlcpcb npth with traces  (Read 4307 times)
Offline tablatronixTopic starter
« on: May 26, 2018, 03:31:10 pm »
using eagle, trying to generate mouse bites with traces.
JLCPCB keeps rejecting my order, but I am failing to see why, or where they are getting these failures from.
"As shown below, the holes makes the lines drilled off"
I have .25 mm drill hits, with ~.25mm hole to trace, 6 mil traces.
min drill is .2mm on their capabilities.
Of course an email conversation with them takes 2 days because of timezone.
I am probably pushing my luck here, and should just use another fab house, but I thought I would try one more time.
eagle 1mil grid
last image is their screenshot, It looks like they are upsizing my holes, or calculating them from profile/outline wrong even though they are in the drill file. baffled.
« Last Edit: May 26, 2018, 04:27:10 pm by tablatronix »
Re: pcb woes jlcpcb npth with traces
« Reply #1 on: May 26, 2018, 03:35:32 pm »
full stackup
Offline matseng
    • My Github
« Reply #2 on: May 26, 2018, 03:51:44 pm »
To me it looks like the holes are too close to the cutout - at least that is what the arrows points to. Some fabs don't like to make holes (and/or copper) close to the board edges...
« Reply #3 on: May 26, 2018, 04:10:43 pm »
Possibly, in my gerbers the cutout is >0.2mm from holes and within capability listed.
But the email said "As shown below, the holes makes the lines drilled off"
Which makes no sense to me from my gerbers, even accounting for drill tolerance of  ±0.08mm.
It is like they are not using profile midline?
Offline matseng
    • My Github
« Reply #4 on: May 26, 2018, 05:05:35 pm »
How wide is your cutout?  I've discovered that many cheap fabs uses what looks like a 1.2mm or even 2mm router bit for the internal slots. This might expand the slot on your pcb and make the edge too close to the hole.
« Reply #5 on: May 26, 2018, 05:33:01 pm »
I think its about 1.2mm but this rejection is the same as last drills will cut traces. The i made holes smaller and added tons of space and still their screenshot does not match my holes.
I dont think cutout is the problem but i will ask them.
Offline DerekG
  • Country: nf
« Reply #6 on: May 26, 2018, 10:26:54 pm »
I would agree. The board shop may mill to the centre of your rectangular (with rounded corners) cut out line, while others will mill right to the outer edge of the line. I personally would have chosen a narrower outline for the cutout (remember it is normally shown on a mechanical layer, not a copper layer).
So, I agree with matseng in that your cutout is too close to your existing pad holes.
I also sat between Elvis & Bigfoot on the UFO.
Offline HwAoRrDk
« Reply #7 on: May 26, 2018, 10:47:52 pm »
Wait, are your mousebite holes in both the mechanical (i.e. board outline) layer gerber file and the drill file? They should only be in the drill file. So if they're trying to route them according to the outside of the lines in the GML then it's unsurprising they're complaining because it looks like it will cut the board completely in two due to the overlap.
The only other thing I can think of is that you didn't put these NPTH in a separate drill file, so they are treating them as plated, and so expanded the hole size to accommodate the plating thickness.
The following users thanked this post: tablatronix
« Reply #8 on: May 26, 2018, 11:25:29 pm »
Yes thank you , I was wondering that also.
So I am wondering why does eagle cam processor put npth in mechanical (board layout,cutouts) ?
(jlcpcb site specifically says "Please use Outline to design if there are many non-plated (NPTH) holes." )  So I assumed they would deal with this fine by comparing the 2.
Maybe I just need to make eagle not put these drills in mechanical somehow.
Any Ideas?
« Reply #9 on: May 26, 2018, 11:32:27 pm »
I guess I will try to just use board outline and milling layer and try that...
« Reply #10 on: May 26, 2018, 11:42:21 pm »
Also I have no idea what dictates the line thickness in the mechanical layer that the cam processor generates when you click cutouts and board outline, Those are not line widths I have set, but maybe I have them set to 0 so they are defaulting.
« Reply #11 on: May 28, 2018, 02:07:56 pm »
Well no rejection this time, Thanks for your help, eagle 9 cam cutouts checkbox auto includes npth holes in mechanical, I have no idea why they do that.
Offline HwAoRrDk
« Reply #12 on: May 28, 2018, 07:00:03 pm »
Excellon drill format includes support for slotted holes, but some PCB manufacturers don't support that, so in that case one needs to put these holes in the board outline gerber to be routed out that way.
« Reply #13 on: May 28, 2018, 08:25:46 pm »
Yeah I am reffering to all npth of any size. I have asked in their forum why this is, id expect this behavior for drill sizes but not in drills or slots. Seems like an odd feature.
Offline vipcircuit.com
  • Country: cn
    • VipCircuit
« Reply #14 on: June 28, 2018, 08:05:32 am »
npth to line 0.25mm, line width 6mil, seems no problem
Professional PCB/PCBA manufacturer-www.vipcircuit.com.
High quality and reasonable price.
