Author Topic: Pentalogix Viewmate Pro DXF to Gerber conversion , drill file how to ??  (Read 2730 times)
Online OverspeedTopic starter
Hello
I use Viewmate ( not the pro version ) since years for minor Gerber modification , I have downloaded the Pro version to make some DXF to Gerber conversion for evaluation before to purchase .
If Gerber files conversion works , I an stuck with the drill file as I create NCtool table , I declare my layer Vias as a PTH ( plated to the hole layer ) and the software provide me a message as no hole is located
If i try to convert by using the pad to hole tool as the soft declare '' no hole found '' , the answer is .... doesn't work
I have try to contact Pentalogix without an answer from them and Pentalogix help files and training video are really poor.
Perhaps someone can explain me how to convert DXF layer to drll ?
Regards
OS
« Last Edit: December 12, 2023, 11:59:24 am by Overspeed »
Re: Pentalogix Viewmate Pro DXF to Gerber conversion , drill file how to ??
« Reply #1 on: December 13, 2023, 07:51:12 am »
Hello
Several days after my emails with screen prints  to Pentalogix I have received an answer , I start to understand the specific method to convert polygon to pad and pad to holes .
I will make tutorial asap that 100% provide a proven conversion .
Regards
OS
« Last Edit: December 14, 2023, 06:14:34 am by Overspeed »
