Author Topic: Pink PCBs..!  (Read 8048 times)
Online mikeselectricstuffTopic starter
    • Mike's Electric Stuff
Pink PCBs..!
« on: March 07, 2013, 03:37:16 pm »
Had an interesting problem today - some ENIG (gold finish) PCBs with white resist turned a pale pink when they went through the oven.
Apparently something in the ENIG cleaning process affected the ink chemistry (the assembly subcontractor had seen this before).
Fortunately I realised that we could just get the resist re-printed & this saved the day with only a day lost.
Day Job: Mostly LEDs
Re: Pink PCBs..!
« Reply #1 on: March 07, 2013, 04:04:08 pm »
Do it as a feature..........
Offline mrflibble
Re: Pink PCBs..!
« Reply #2 on: March 07, 2013, 05:13:14 pm »
What he said. Add a flower motif to the silkscreen, slap an ar-suckmy-duino on it somewhere and hawk your wares on kickstarter. Bound to sell!
Offline Bored@Work
Re: Pink PCBs..!
« Reply #3 on: March 07, 2013, 06:11:27 pm »
Time to connect to your inner feminine side.
Offline Smokey
  • Not An Expert
Re: Pink PCBs..!
« Reply #4 on: March 07, 2013, 07:00:40 pm »
before and after pictures?
Re: Pink PCBs..!
« Reply #5 on: March 07, 2013, 08:34:35 pm »
Offline nicknails
Re: Pink PCBs..!
« Reply #6 on: March 08, 2013, 01:17:00 am »
We use white resist on all of our boards and I've seen this happen a few times.  Not to that extent, more of just a pinkish hue.  We've never really seen it as a problem and all of our parts are encapsulated.
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
Re: Pink PCBs..!
« Reply #7 on: March 08, 2013, 09:18:16 am »
Why not introduce a line of electronic Barbie Dolls? You could call them Barbduinos  :-DD
Offline kc0ngu
Re: Pink PCBs..!
« Reply #8 on: May 05, 2013, 07:42:36 pm »
Does it only happen over ENIG?
If it happens with regular HASL, it might not be the ENIG, it might be migration of a blue, violet or similar pigment/dye in the resist. White inks sometimes use these added colors to increase the apparent 'whiteness' of the white ink, especially if a cheap or low quality white pigment is being used. Most times these added colors dont show, but reflow and solder temps can play rough with (poorly) formulated inks/resists.
Not a real answer I know, just my 2cents from 30+ years of designing these coatings and (trying to) solve similar issues on the PCB shop floor.
Re: Pink PCBs..!
« Reply #9 on: May 05, 2013, 09:18:00 pm »
The PCBs were re-printed with the same resist ink, and came out fine, so pretty sure it was something that happenned during plating.
The PCBs were for this BTW...http://www.uva.co.uk/work/continuum
Offline EEVblog
Re: Pink PCBs..!
« Reply #10 on: May 05, 2013, 10:12:03 pm »
Yes, I've seen this before quite a few times, not uncommon. Although I thought it was pretty much history these days.
Offline jmole
    • My Portfolio
Re: Pink PCBs..!
« Reply #11 on: May 05, 2013, 11:28:36 pm »
beautiful piece. how'd you end up working with these folks?
Offline kc0ngu
Re: Pink PCBs..!
« Reply #12 on: May 06, 2013, 12:46:48 am »
OK, thanks for the update Mike, I will have to have a think about what else might be in going on, appreciate your work (and videos
's) as always, impressive end result/installation.
Offline Corporate666
  • Remember, you are unique, just like everybody else
Re: Pink PCBs..!
« Reply #13 on: May 15, 2013, 11:46:25 pm »
Can you disclose who the PCB manufacturer was?
I just got a very expensive quantity of white soldermasked boards with ENIG plating.... haven't used any yet but maybe I should run one through the reflow process to see if it turns pink!
It's not always the most popular person who gets the job done.
