Author Topic: power place connections/thermal pad  (Read 1175 times)
Offline gogomanTopic starter
« on: July 21, 2018, 02:26:12 pm »
Hi  I have not layout a board in a while,
Given a four layer board (inner: power ground) using smd components, can the connections to the inner layer be made directly or must a thermal pad/relief be used.
Using a  via  with a angular ring of 20mil  and hole of 10 mils,  what expansion value  is recommend for a thermal relief?
If two thermal relief intersect,  resulting in 2 out of 4 spokes connecting to the plane,  does this pose a manufacturing issue.
thanks
« Last Edit: July 21, 2018, 02:37:17 pm by gogoman »
Offline borghese
  • Country: si
Re: power place connections/thermal pad
« Reply #1 on: July 22, 2018, 07:45:10 am »
The thermal relief are normally used with PTH components
With SMD pad there is normally a short track for connection to the power plane that act as thermal relief;
Cheers
Borghese
