Author Topic: Printing several gerber layers on the same page and negative print  (Read 5246 times)
Offline EmilTopic starter
  • Country: no
    • ZeptoBit
Hi.
I'm looking for a way to print several gerber layers on the same page.
I want the layers to be seperate, not placed over each other like they would be on the finsihed board. My reason for this is that I want to print to a laser film to use for UV-exposure when making PCBs. The film is a bit expensive so if I'm going to use one sheet for the top copper, one for the bottom copper, one for the top solder mask, one for the bottom soldermask, one for the silk screen etc. it get's expensive.
I have googled this and tried a few programs, but not found a solution yet.
I use KiCad for the PCB layout, so it would be niceto use it's gerber viwer for this, but as far as I can tell it will only let me print one layer on each page (or all on top of each other). I also tried the gerber viewer in Geda, can't find a way to do this in that program either. I'v also downloaded GC-Prevue, but not found a way make it do what I want.
I'm also looking for software that will let me print a negative version of the gerber. (For use with negative photoresist.)
Any suggestions?
Offline chrome
Re: Printing several gerber layers on the same page and negative print
« Reply #1 on: August 15, 2012, 08:46:34 pm »
Eagle lets you print from your design and allows you to position the image on the paper but it also allows you to export to an black and white image, you can then merge these images in paint or whatever you want.
I assume other programs can do this easily too though.
Offline Short Circuit
    • White Bream electronics R&D
« Reply #2 on: August 15, 2012, 08:56:33 pm »
http://www.pentalogix.com/viewmate.php
Of course you need to move the layers manually.
After that, you can do a b&w print with all layers combined.
If I understand correctly, you can use the free version to load & edit the files and print them.
Just no saving of project files or gerber exports, nor any advanced editing.
  • Country: no
    • ZeptoBit
« Reply #3 on: August 16, 2012, 08:02:24 am »
Thank you for the reply.
I downloaded the free version of ViewMate and it does exactly what I need.
