On a two-layer board, I would place a bypass capacitor next to an IC and run power traces to the cap and on to the IC power pin.
Now that I'm using four layers, I can do the same with SMD devices. Now I want to use a PT2399 digital delay chip, which is only available as a 16-pin dip. So the power pin is 'drinking' from the power plane, with the 100nF capacitor 'nearby', rather than the capacitor literally being a local trough for the IC to 'drink' from. Does this matter?
Should I have a trace from the SMD capacitor to the power pin? Or have the capacitor connect to the power plane using a via, next to the power plane? Or am I OCD?
Tom
