Author Topic: Protel 99SE - autoroute all except GND net?  (Read 1101 times)
Offline CirclotronTopic starter
« on: August 23, 2019, 07:01:30 am »
I want to autoroute an entire board except the ground net, then pour a ground polygon. I can't seem to find a way to exclude the ground net from the autorouter. Any ideas?
Offline tautech
Re: Protel 99SE - autoroute all except GND net?
« Reply #1 on: August 23, 2019, 07:06:44 am »
Route just the ground net leaving appropriate spacings to then Autoroute all the other nets.
Then do your polygon ground pour.
« Reply #2 on: August 23, 2019, 07:14:49 am »
That kinda worked, but when I autorouted the other nets it disturbed the positions of the ground tracks. What I want to do is give the other tracks the greatest freedom of placement without any ground tracks present.
Offline tautech
« Reply #3 on: August 23, 2019, 07:24:58 am »
Been a while since I’ve used 99SE but can’t you lock a net once routed ?
Lock Primatives ?
Or turn OFF Shove ?
« Reply #4 on: August 23, 2019, 07:25:59 am »
I found a way that partially works. Pour the ground polygon first, then autoroute the other stuff. Then regenerate the polygon. For the most part it sees the ground points are all connected to the polygon so it leaves them alone, but in a number of places it still puts tracks from one ground pad to another despite these pads beeing connected to the polygon.
Offline tautech
« Reply #5 on: August 23, 2019, 07:29:56 am »
Tweaking the layout should fix that.
« Reply #6 on: August 23, 2019, 07:32:19 am »
^^ Those unnecessary tracks were bottom side tracks. The topside ones I couldn't see because of the topside polygon. So the basic problem still exists - the ground tracks running all over the place take up lots of space when they don't need to be there, and make the signal routes messy for no good reason.
Offline tautech
« Reply #7 on: August 23, 2019, 07:40:31 am »
You should be able to turn OFF layers so to better see what’s going on.
IIRC for my first board with a pour I’d routed the ground then poured over it.
