Author Topic: Proteus 8 properties  (Read 2605 times)
Offline BFXTopic starter
  • Country: sk
« on: February 02, 2019, 02:45:46 pm »
Do somebody know how to change font size in Proteus 8 schematics Label? (See pic.)
Those in right down corner (sorry I don't know exact technical name for this label in english).
As you can see at picture if text is long there is a problem with overwrite right section an so.
I would like to make text smaller or if its so long in two lines.
Thx
Offline DerekG
  • Country: nf
Re: Proteus 8 properties
« Reply #1 on: February 02, 2019, 11:55:46 pm »
It is a while since I used Proteus but I believe you can make the entire properties box larger to fit in more text.
I also sat between Elvis & Bigfoot on the UFO.
  • Country: sk
« Reply #2 on: February 04, 2019, 12:40:05 am »
I'm not sure that it is possible to make this box bigger.
Online wraper
  • Country: lv
« Reply #3 on: February 04, 2019, 12:48:08 am »
Template->Goto Master Sheet, then right click what you need to edit -> Edit Properties.
You can create one as you wish.
  • Country: sk
« Reply #4 on: February 09, 2019, 11:21:41 pm »
Thank you so much, it works great!  :-+
