EDA > General PCB/EDA/CAD Discussions
Protoboard RF Area
(1/1)
CJay:
This may take a little effort to explain so bear with me
I'm designing a protoboard for use with a DDS chip, it's all nice and simple so far but I want to add an area where I can experiment with filters, amps, mixers etc..
To that end I want to design in an area of board with a matrix of individual pads on top and a gorund plane underneath. That in itself is simple, but the twist is that I want to have a hole through the pads that's *not* a via to the ground plane so i could solder components to the top pad alone or thru to the ground plane.
I can add copper pour to the bottom layer, I can add pads to the top layer but it doesn't fill me with confidence that they'd be drilled or not plated through, how do i check?
Navigation
[0] Message Index
Thanking...
Go to full version
