Author Topic: Question about SQUARE cutouts  (Read 6714 times)
Offline atwozTopic starter
« on: June 27, 2012, 01:27:19 pm »
Hello Forum. I am designing a new board that will have several square cutouts inside the board. The question is: Can a standard fab house do square cutouts?
I believe they use a drill bit or something similar to cut out the square hole, however since its a round tool, the inside corners of the square wont end in a corner.
Does anyone have some experience with square cutouts??
Thanks!
Offline free_electron
    • SiliconValleyGarage
Re: Question about SQUARE cutouts
« Reply #1 on: June 27, 2012, 01:30:51 pm »
If you have a phenolic board you can have those die-punched.for a fiberglass board punching works if the pcb is less than 20 mils thick.
Otherwise it is routing.... And that leaves round corners. No escaping. You can ask a cleanup rout using a 1mm bit which gives the corner a .5 mm radius. But you will pay extra
Offline _Sin
« Reply #2 on: June 27, 2012, 01:41:02 pm »
Unless you can convince the fabricator to use a reulaux triangular drill bit :)
Programmer with a soldering iron - fear me.
« Reply #3 on: June 27, 2012, 01:43:36 pm »
Thanks for the fast replies!
I guess I will have to overshoot (don't know the right term) the cutout. Since I have to fit square connectors inside those holes I will just have the drill bit overshoot in the corners so the connector fitrs. I will end up with a square cutout with some circles in the corners, ugly but I guess I have no other choice.
I will be using that board as a front panel.
Offline digsys
    • DIGSYS
« Reply #4 on: June 27, 2012, 01:57:05 pm »
Since I have to fit square connectors inside those holes I will just have the drill bit overshoot in the corners so the connector fits.
Don't be so hasty. With a 40/50 thou router, the corners are very small, and unless the connectors are made of metal, they fit beautifully snug in
an exact square hole. I've done it many times. In a worst case, it's just a tiny "nick" with a small square file.
Offline Short Circuit
    • White Bream electronics R&D
« Reply #5 on: June 27, 2012, 02:09:13 pm »
You can add some drill holes in the corners to reduce the corner radius
Offline bronson
« Reply #6 on: May 02, 2014, 06:54:07 am »
So how are these square bottom-mount LEDs handled?  A square LED in a round hole would look terrible, and I can't imagine everyone ordering this LED is using a phenolic PCB with die cut holes.
http://www.digikey.com/product-detail/en/APTR3216SGC/754-1171-1-ND/1747888
What am I missing here?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #7 on: May 02, 2014, 07:36:16 am »
if the quantity is managable. you can pick cheaper service (round corner), dont care and whatever. and then buy a square file, or triangle if NA, file the corner yourself. using skill and dremel and cutting disc or diamond bit somesort will also do the trick, ymmv.
Offline nihilism
« Reply #8 on: May 02, 2014, 08:53:46 am »
allow enough clearance over the led size to compensate for the radius of the corners which could be as little as 0.5mm a side?
Offline kizzap
« Reply #9 on: May 02, 2014, 10:26:00 am »
common method to get around the issue in most designs is as follows:
http://www.omwcorp.com/img/cutawaycornerspocket600x514.jpg
Basically you run the router out a little bit 45° from the corner, which solves the square peg/round hole issue.
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline bronson
« Reply #10 on: May 02, 2014, 04:56:38 pm »
Great replies, but why are so many of these bottom-mount LEDs are square?  If you can't see the overdrill anyway, why not just make 'em round and easy for everybody?  There must be some application I'm not aware of.
Hoping to manufacture these one day so, unless the PCB fab has a mortising machine, I'm probably only allowed router tricks.  I'll have to buy some parts and play with kizzap's suggestion.
Offline Niklas
« Reply #11 on: May 03, 2014, 01:24:22 pm »
This week I had a look at a problematic smoke detector produced in Asia that had stamped cutouts in 1.6 mm thick FR4. The manufacturer could easily have gone for routing with a 2.4 mm drill bit for these smoke chamber snap in holes as this was inside a plastic box. Instead the board manufacturer used a stamping tool, probably to reduce cost for high volume production.
The finish on the edges on the stamped FR4 is not that great. Uneven and a bit rough, similar to what you get with v-cut. Why not investigate what you can do with traditional routing and a bit of artistic creativity? Extend the milled rectangle to become an S-shaped trench? If you can't hide it, try to exploit it instead.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #12 on: May 03, 2014, 07:18:08 pm »
Don't know why the datasheet drawing has a square "hole" outline, but the dimension is correct.
The protruding body is listed as 1.4 x 1.6 mm.
The diagonal is sqrt(1.4^2 + 1.6^2) ~= 2.1 mm.
So a round hole >= 2.1mm will suffice.  Probably 2.6 would be a good idea?  If you want to route that for a little better straight-sidedness on the hole, you can, but you'll probably incur the cost of a route (...which probably isn't anything, and if your board outline is already non-rectangular, a rout process is required, regardless).
Seven Transistor Labs, LLC
