Author Topic: Reference book for PCB layout?  (Read 2506 times)
Offline FrilloTopic starter
« on: May 30, 2018, 08:35:53 pm »
Hello,
I just finished my degree in electronics engineering, and I'll be starting on my first real job in a month or so, where I will be doing some PCB layout (and other tasks).
I have some experience doing PCB layout already, but I want to get better.
So the question is:
Can any of you recommend some book to use as a reference for doing PCB layout (if such a thing exists), or can you recommend other litterature, which outlines the dos and don'ts?
Re: Reference book for PCB layout?
« Reply #1 on: May 30, 2018, 08:50:29 pm »
Offline IconicPCB
« Reply #2 on: May 31, 2018, 04:30:31 am »
IPC publications are your friend
Offline cat87
« Reply #3 on: July 06, 2018, 11:59:35 am »
I guess something a bit more concree and closer to what you're looking for would be Howard Johnson's  High Speed Digital Design: A Handbook of black magic. You have basically everuthing you nees there,  from doo's and don'ts to examples and calculations.
Also try looking at his other book(s)
Offline RomDump
« Reply #4 on: July 06, 2018, 02:30:50 pm »
"Right the First Time, A Practical Handbook on High Speed PCB and System Design, Volume 1"
There is also a Volume 2.
https://www.speedingedge.com/products/right-first-time/
RomDump
