Author Topic: Request for Recommendations on ESP32-C3-MINI-1-N4 Schematic and PCB with LiPo Ch  (Read 2484 times)
Offline achraffffTopic starter
  • Country: tn
Hello everyone,
I’m working on a project  using an ESP32-C3-MINI-1-N4 module. Here is the first version of my schematic and PCB for this project. The design includes:
- An ESP32-C3-MINI-1-N4 for WiFi/Bluetooth connectivity,
- A charging circuit based on the TP4056 for a LiPo battery,
- A 5V to 3.3V power conversion using an MIC5205-3.3 regulator to power the ESP32.
I would appreciate your feedback and recommendations on the following points:
1. The layout of the components and trace widths, especially for power lines.
2. The management of LiPo battery charging and discharging to prevent any risk of overcharging or over-discharging.
3. Any suggestions to improve the efficiency and stability of WiFi/Bluetooth connectivity, considering the use of the onboard antenna.
Thanks in advance for your insights and advice!
« Last Edit: October 31, 2024, 11:45:28 pm by achraffff »
