Author Topic: Required clearance for opto-isolated DALI comms signal?  (Read 1681 times)
Offline ocsetTopic starter
« on: August 10, 2017, 08:07:05 pm »
Hello,
We have  a DALI signal which comes into our non isolated offline LED driver. The DALI signal is isolated from the receiver in the  LED driver by a TCLT1000 optocoupler..
TCLT opto datasheet
https://www.vishay.com/docs/83515/tclt1000.pdf
The problem is , that its too long to fit on the PCB. We need to use a smaller opto…..
Do you think we will be able to use the LTV-356 optocoupler which is 3mm shorter….
http://www.mouser.com/ds/2/239/LTV-356T%20Series-1308-301539.pdf
Will the clearance still be adequate with the LTV-356 opto? Also, if not, then can we just use a cutout in the PCB to increase clearance  like that?
Offline floobydust
Re: Required clearance for opto-isolated DALI comms signal?
« Reply #1 on: August 10, 2017, 10:27:48 pm »
What is your isolation voltage requirement for your product's regulatory approvals?
The product is double-insulated?
The following users thanked this post: ocset
