Author Topic: RF RANGING PERFORMANCE REDUCED FROM 90M TO 40M - NEEDED HELP  (Read 7365 times)
Offline Anirudh_THABJUL_SBTopic starter
« on: August 29, 2016, 09:40:42 am »
Hello Everyone,
I am Anirudh THABJUL, an Electronic engineer working for a company called "SECOND BRIDGE", We are based on Paris.
In our applications, We are measuring distance between two 10 layer PCB's through 802.15.4 protocol. To achieve this, We are using mainly
1. IMX6 Processor (Main processor)
2. SAM4E (Secondary processor)
3. RF215 + Antennas for RF ranging section
Our issue is when we just measured distance between two PCB by putting the IMX6 in ideal state we are able to range upto 90M (Refer the attachment1) but when we activate the IMX6, ranging is reducing to 40M (50 % performance reduction).
Can anyone explain this RF interference phenomenon? If possible please suggest us the possible ways to solve this problem like some reference sites or some reference documents?
Thank you.
Regards,
Anirudh THABJUL
Offline Kilrah
Re: RF RANGING PERFORMANCE REDUCED FROM 90M TO 40M - NEEDED HELP
« Reply #1 on: August 29, 2016, 09:43:13 am »
Likely EMI from the processor. Might need shielding, power supply filtering improvements, PCB layout improvements...
Also don't post duplicate topics.
The following users thanked this post: Anirudh_THABJUL_SB
« Reply #2 on: August 29, 2016, 10:01:17 am »
Hello Kilrah,
Thank you for your reply. I have removed other duplicate post. I am sorry i am new to this group.
We ahave mentioned
"Might need shielding, power supply filtering improvements, PCB layout improvements"
Can you please share some more info if you have like some online links or document attachments about power supply filtering improvements
Thank you.
Offline VK5RC
« Reply #3 on: August 29, 2016, 10:22:13 am »
Does the RF share any power components e.g. +/- voltage rail or ground with the microprocessor?
I have seen some designs where the RF has its own linear regulator and isolated ground as well.
« Reply #4 on: August 29, 2016, 10:51:24 am »
Hello VK5RC,
Yes the RF share the Positive and negative power component tracks. So is there a way to fix this issue on existing prototype itself.
Offline Edsoncan
  • Country: br
« Reply #5 on: August 29, 2016, 11:02:48 am »
Do you have spectrum analyzer?
If is it possible that the EMI can affect the TXO frequency?
Are you using a pcb antenna or a cable antenna?
Offline bitslice
« Reply #6 on: August 29, 2016, 11:04:44 am »
(not an RF person)
Something I've noticed in other people's RF designs is that every chip or semiconductor is linked to the power rail via an inductor, presumably to filter out power rail noise.
I'd probably stick a uP inside a metal can
Another technique I've seen is to use a spread spectrum design for the uP clock
« Last Edit: August 29, 2016, 11:07:53 am by bitslice »
Online Psi
« Reply #7 on: August 29, 2016, 11:09:07 am »
Try with the IMX6 running at a few different clock frequency, it may simply be your IMX6 clock is a harmonic of the RF frequency.
« Reply #8 on: August 29, 2016, 11:16:35 am »
Unfortunately, We don't have spectrum analyzer with us. We are using four ceramic antenna like in the image attached below.
« Reply #9 on: August 29, 2016, 11:18:12 am »
Hello Psi,
Thank you for your reply. We will definitely try this technique.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #10 on: August 29, 2016, 11:42:43 am »
Sounds a lot like you're coupling digital noise from the uC into your RF. Have you measured the power supply noise at the RF part with/without the uC active?
Offline Edsoncan
  • Country: br
« Reply #11 on: August 29, 2016, 11:44:57 am »
You calculated the mca? (micro channel)
Your  antenna traces are so thin...
« Reply #12 on: August 29, 2016, 11:45:45 am »
Not yet, We will try to calculate it. Can you please explain me what can we conclude exactly after all the noise calculations?
« Reply #13 on: August 29, 2016, 11:48:02 am »
Do you mean be impedence matching? If yes, Yes we have maintained track widths as per the calculations proposed after imepedence calculations.
Offline Edsoncan
  • Country: br
« Reply #14 on: August 29, 2016, 12:17:20 pm »
I am sorry my english is not good.
I refer  Coplanar Waveguide  https://en.wikipedia.org/wiki/Coplanar_waveguide
« Last Edit: August 29, 2016, 01:02:54 pm by Edsoncan »
Offline Ice-Tea
« Reply #15 on: August 29, 2016, 12:34:06 pm »
Calculate? No, measure. With a decent scope. The PDN (Power Delivery Network) to your RF part must be as clean as possible. If your digital part shares the same network, it will inject noise on the power rail, which will end up in the RF part and which is most likely degrading your RF noisefloor.
Offline nctnico
« Reply #16 on: August 29, 2016, 02:26:20 pm »
I second the suggestion of filtering the power supply to the RF section. A spectrum analyser may be a cheaper than a multi-GHz oscilloscope and you can connect a 50 Ohm active or passive probe to a spectrum analyser to look at the spectrum present in a PCB trace.
I'm also missing lots of vias to stitch the top copper pours to the inner ground plane. The top copper pour which is supposed to be the coplanar waveguide ground may be acting as an antenna as well.
« Last Edit: August 29, 2016, 02:28:11 pm by nctnico »
Offline Gribo
« Reply #17 on: August 29, 2016, 08:42:32 pm »
Few more comments regarding your design:
Your RF traces are long and travel in unnecessary bends and twists. Keep them as short and as straight as possible.
Add shielding vias to the ground on both sides of the RF traces, for 2.4GHz, roughly 1cm between each via.
Try soldering an SMA connector instead of your ceramic antenna, and see if you get the required output power, with a spectrum analyzer.
I am available for freelance work.
Offline Ice-Tea
« Reply #18 on: August 29, 2016, 08:51:02 pm »
You may also want to check if you can read out stuff like noisefloor, RSSI, SNR from you device and check with/without the uC active.
