You literally do not understand what's it's for.
perhaps...
judging their move to AWS I am assuming everybody else
is likely to use their facilities.. a subscription or other
model of service rent.
Today, Amazon Web Services, Inc. (AWS), an Amazon.com, Inc. company, announced that Arm, a global leader in semiconductor design and silicon intellectual property development and licensing, will leverage AWS for its cloud use, including the vast majority of its electronic design automation (EDA) workloads. Arm is migrating EDA workloads to AWS, leveraging AWS Graviton2-based instances (powered by Arm Neoverse cores), and leading the way for transformation of the semiconductor industry, which has traditionally used on-premises data centers for the computationally intensive work of verifying semiconductor designs.
and may be I am wrong assuming they will let their customers
access their IP outside such facilities ...
But with such big move that vast amount of IP and money
most likely will not be available outside that fence..
Perhaps I may be wrong.. and customers will
have outside access to their IP ?
