Author Topic: Selecting a power supply for a DC DC converter  (Read 3007 times)
Offline diracshoreTopic starter
« on: February 19, 2012, 03:25:42 am »
Hi all,
I have a PCB with this DC-DC converter I am trying to find a power supply for.
Is it better to supply a lower or higher voltage in the stated input range ? Or does it not matter at all ?
Which of these is more suitable ?
http://www.ebay.com/itm/48V-DC-7-3A-350W-Regulated-Switching-Power-Supply-Fast-from-USA-41-56V-/160691584377
http://www.ebay.com/itm/32V-40V-Adjust-DC-9-7A-350W-Regulated-Switching-Power-Supply-Quality-from-USA-/160691581782
Or is there another product I should be looking at ?
If you would like context on the project,
https://www.eevblog.com/forum/general-pcbedacad-discussions/pcb-with-virtex-5-fpga%27s/
Thanks !
« Last Edit: February 19, 2012, 03:28:38 am by diracshore »
Offline mobbarley
Re: Selecting a power supply for a DC DC converter
« Reply #1 on: February 19, 2012, 03:37:34 am »
It shouldn't matter. its rated at 38-55v, anything in that range with enough current capability should be fine.
I would be going with 48V as it is very common, and it is in the upper middle of the input voltage range - likely to be more efficient too.
Offline Zero999
  • 0999
« Reply #2 on: February 19, 2012, 12:19:31 pm »
This sounds like a waste of time to me, rather than buying a power supply to work with this DC-DC converter, you should buy a 12V 20A power supply and be done with it.
Offline markus_b
« Reply #3 on: February 19, 2012, 01:16:07 pm »
Your power supply is likely designed for telecom applications. 48V is the standard telecom supply voltage and there is a lot of equipment designed for it. You'll find plenty of power supplies for 48V, just google it.
I sort of agree with Hero999, if your objective is to get to 12V, then a 12V supply costs the same or is cheaper than a 48V supply. Mostly because 48V has mostly industrial applications, where for12V you'll find lots of consumer stuff too.
Your best bet may be to sell it on Ebay...
Markus
A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible.
« Reply #4 on: February 19, 2012, 07:36:25 pm »
Perhaps, but I'm way too curious now.
The reason I don't bypass the converter is because there are other converters on the board sharing the input line and I also want to power them. I think you are right it is quite probably telecom equipment, 48v is correct.
With this power supply though I am wondering what use it was designed for. The store sells equipment for cars and trucks. Is the output of this supply stable enough for digital equipment ? There is a long list of specs on the page but I'm not sure which are relevant.
« Last Edit: February 19, 2012, 07:50:36 pm by diracshore »
