Author Topic: Silk screen on an exposed pad with no solder mask  (Read 2970 times)
Offline itdontgoTopic starter
    • IoT Manufacturer
« on: November 06, 2014, 05:02:20 pm »
Just realised this should be in here:
Does anyone know if the silk screen is applied after the PCB is solder levelled/plated so that a silk screen can be applied to what would normally be a pad?
You obviously would get a DRC error if you put text on a pad but could a PCB be produced this way intentionally.  It's a pad that is not intended to be soldered.
Offline wraper
  • Country: lv
Re: Silk screen on an exposed pad with no solder mask
« Reply #1 on: November 06, 2014, 05:10:56 pm »
PCB house will remove any silkscreen over exposed copper. If you ask pCB service to to this, might be possible. However adhesion might be not good.
« Last Edit: November 06, 2014, 05:13:39 pm by wraper »
Offline amyk
« Reply #2 on: November 10, 2014, 01:42:26 pm »
Usually it's an error but apparently some of them will print silkscreen over pads if you really want them to:
https://www.eevblog.com/forum/beginners/removing-goofed-up-silk-screen-from-pads/
https://www.eevblog.com/forum/manufacture/silkscreen-clean-up-from-iteadseeedetc/
